Question about Garmin 340c Fish Finder Dual Frequency Saltwater
A65 Raymarine combo gps plotter fishfinder
Hi, I have a A65 Raymarine it is missing the kit which would include the cables antenna and transducer, where can I get these parts and how much.
troble2
Changes.
Posted on Jan 09, 2009
  • 3 Answers
Your local marina should be able to tell you and they most likely are a dealer for seadog or diversified which will sell your parts just give them your model or just take the unit in with you
Posted on Oct 21, 2008
Water temp way off. where is the temp thermister located to replace it
Your water temp is measured by your transducer. There is a slight possibility that the transducer is OK and it is that the DSM25 is not relaying the TEMP info to the A65 display. Your best bet is to either try and find another DSM25 (friend or dealer) that you could try and plug in with your system. If the problem is still there, it is your transducer. If the problem goes away, then you would have to send in your DSM25 to the repair center to have it repaired. I believe the going rate for the DSM25 is $175 for a complete rebuild.
Sep 14, 2010 | Raymarine A65 Combo GPS...
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
Hello! Our Raymarine A65 will not start up. It starts a boot process but does not show "Raymarine A65" on the display and no chart is displayed as it usually does. Regards Odd
Probably a bad printed circuit board, just had to send mine in to have it repaired. When I hit the power button, I did hear a beep, but then nothing displayed. Mine was still under warrenty, so don't know the repair cost if yours is not.
Jul 15, 2009 | Raymarine A65 Combo GPS...
A-65 screen has fine scratches/clouds
My Raymarine A65 was so bad in daylight I could not read the screen. Used Never Dull polish from ACE hardware, similar to Brasso, and it took every scratch and cloudy mark off the screen. The can documentation includes glass as one of the items it?s safe to use on. Looks new again, Good Luck, Paul
Apr 08, 2009 | Raymarine A65 Combo GPS...
Troble2
Hi, my name is adam and i would love to graciously help you. In your description you stated you need a wiring kit. I have a link included from ebay and you can go on there and hopefully find what you need. http://shop.ebay.com/items/?_nkw=A65+Raymarine+&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=A65+Raymarine+fish+finder+wiring&_osacat=0
Jan 09, 2009 | Garmin 340c Fish Finder Dual Frequency...
A65 Transducer
jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Sep 11, 2008 | Raymarine A65 Combo GPS...
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Log and trip function not registering
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Nov 06, 2007 | Raymarine A65 Combo GPS...
Garmin 340c Fish Finder Dual Frequency Saltwater Logo
377 people viewed this question
Top Garmin Boating Experts
TO Lady
Mohamed Ismail
Mohamed Ismail
Are you a Garmin Boating Expert? Answer questions, earn points and help others
