Question about Whirlpool LER3624JQ Electric Dryer
Whirlpool LER3624JQ My dryer was working perfectly well and then the next thing I knew, I went to start another load and nothing happened. I waited awhile (like an hour) and tried again and nothing. The dryer won't start at all and I don't know what I should do?
  • patrickj71 Oct 22, 2008
    I have same problem: dryer was working fine, opened the door to check the load and dryer wouldn't restart. I have checked the breaker, door switch, motor turns without resistance, everything looks fine, and dryer has power to the back panel...it just won't start.
  • Anonymous Dec 29, 2008
    My dryer worked just fine but now it will not start. I was told that ir could be the breaker / fuse in the dryer. I was told to pull the back panel off and locate the breaker / fuse close to the heating element. That I could not find nor can I find anywhere that "show" a diagram of the that area.
    Problem Solver:
  • 4 Answers
Check the breakers,check the belt, check the heating element,and check door switch majke sure it isnt loose or broke or something.All dryers are fairly uncomplicated.Last check wiring and motor.
Posted on Oct 16, 2008
My dryer was working fine this morning i tried to dtart it anddid nothing no sound nothing is just not starting i already check the breakers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Whirlpool LER3624JQ Electric Dryer
Just dried a load of clothes and every thing worked fine. Put in another load to dry and says it is sensing. Nothing else happens
Here's a quick thing to try. Unplug the dryer, wait a minute and plug it back in. Try drying the clothes again. If this doesn't work, you will require troubleshooting from one of the category experts for dryers. Good luck.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer starts when it wants too
you maby have a weak thermal fuse.
Mar 15, 2009 | Whirlpool GEX9868J Electric Dryer
Whirlpool LER3624JQ will not heat
remove the back panel,you will see the heater box,the fuse which turns the heater box on is at the top of the heater box,replace that and it should work,most of the time what blows the fuse is cloogged wall or dryer vent holes-mike
Feb 27, 2009 | Whirlpool LER3624JQ Electric Dryer
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
I have a Whirlpool Dryer (Model # LER 3624JQ0) that just stopped. I push the "Push & Start" Button and get absolutely nothing. Remind you, this dryer never did turn off, I had to manually stop it each time...
Check the thermal fuse on the exit chute, white plastic. You can tape the wires together to test. If the dryer runs, replace it. Part # 3392519. Thermo next to it is also bad, part # 694674. Replace it and your timer will run down. Both parts available at www.timerking.com. Hope this helps!
Jan 14, 2009 | Whirlpool LER3624JQ Electric Dryer
Whirlpool dryer
try this at your own risk lol set the timer open the door hold down the door switch and give the tub a hard spin with your hand clockwise see if it starts if it does the switch in the motor is bad and you will need to replace or clean the motor
Feb 11, 2008 | Whirlpool LER3624JQ Electric Dryer
Whirlpool LER3624JQ Electric Dryer Logo
130 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
