I have a 2003 jeep liberty limited edition. My battery died and i replaced it and when i started up my jeep again i went to listen to a cd and it wont go to the cd menu anymore. what could be the problem?
    Scholar:
  • 70 Answers
Your Jeep has a security feature.When you replaced battery it caused the cd player to lock up. You need to contact your local Jeep dealership to obtain the security codes to unlock cd player. They usually have that information available. Good Luck
Posted on Oct 17, 2008
How can I get my car radio unstuck from one station?
Try disconnecting the negative ground (-) cable from the battery. That will disconnect power to everything including your radio. It might reset it self when you restore power by reconnect the negative ground cable to the battery.
May 19, 2014 | Pioneer Deh-4100 Single Din Cd Player...
How to remove rear door panel on 2003 Jeep
I am assuming you are asking about the 2003 Jeep Cherokee, these are the instructions for the Cherokee, if not, please repost your question specifying which Jeep you have.
Remove all screws securing the interior door panel on. There is a screw on the top portion, and two in the handle.
  • 2 Gently pull on the interior door panel to release the plastic clips that fasten the panel. Use caution to avoid damaging the plastic clips.
  • 3 With the door panel loose, release the two wire connections to the window- and door-lock switches. You must also remove the lock-mechanism poles.
  • 4 Remove the four screws holding on the speaker. Remove the wire connector and set the speaker aside.
  • 5 Remove the window seal by gently pulling. Make note of how each wiring harness is fed through the door panel.
  • 6 There are two clips that secure the window to the track. Using needle-nose pliers, gently pull the clips off of the window. Carefully lift the window out of the track and set it aside.
  • 7 Remove the motor from the track system by removing the three bolts holding the motor to the track. Remove the unit from the door and place it on a flat surface.
  • 8 Remove the lower cable guide by pressing on the tab with a screwdriver and releasing the guide assembly. You must also remove the window-guide mechanism. Make sure it is turned so that you can connect the cable in the guide.
  • 9 Install the replacement window motor and guide assembly onto the door panel using the three bolts. Make sure the cables are aligned properly before reinstalling the window in the vehicle.
  • 10 Install all peices in the reverse order.
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNocSDED
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNosJL4f
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNp4YDQ0
    Aug 23, 2010 | Audio Players & Recorders
    Trying to hook up 2 Hi Fi speakers to a reciever
    Red left to Red left speaker
    Black left to Black left speaker
    then repeat for right speaker
    turn on amp play somthing quite to start, check all is working. To check speakers are in phase play a bit louder and stand exactly in middle, bass should be defined and central, it helps to close eyes and listen. If not central and defined change over Red and Black on one side only then listen again with the same test.
    Start flat with eq section adjust as you like when listening to something you know and like.
    After all is working ok then make it louder.
    Sorted!
    Sep 16, 2009 | Audio Players & Recorders
    Protect error on agv8500
    Hi there. I have the same unit. A darn nice piece of hardware. A couple of months back I noticed my cooling fan making noise. A few days ago I got the "PROTECT" message and the unit wouldn't power up. I turned it off for three days and it started playing again. Now I'm pretty sure it went into protect mode because it overheated. I just tried finding a Teac replacement fan and didn't see one on the web. My solution will be to adapt a small computer-type fan onto it to keep things cool. It works too well to let it die! Good Luck, Gborchers. GROGSTER
    Nov 15, 2008 | Teac Audio Players & Recorders
    Kenwood KDC-MP832U display not working
    I had this problem! It was the Cars Battery. Kenwoods unit's fade or go completely blank when there is little power to power the stereo. Try charging your battery or grabing a new one from a scrappy! I was all over the net looking for help but finally sorted it!
    P.S. My younger brother had to do the exact thing and it worked for him as well!!!
    Jul 20, 2008 | Kenwood 1080VR Receiver
    No receiver display...no audio out
    cheak displeys wires pluged in tight does sterio get hot then u see it go off
    Jan 23, 2008 | Kenwood VR-2090 Receiver
    Denon avr-1905
    Yes...and no it's not worth saving,,,,don't ever buy another Denon....! Worst Warranty, Worst Tech Support!!!! Cheap units...
    Nov 28, 2007 | Denon AVR-1905 Receiver
    173 people viewed this question
     Grubhead
    Grubhead
