Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
Extend Range ?
This router reaches one of my laptops, but not all of them. How do I extend it? Should I:
  • build a cantenna
  • get a better antenna
  • get an extender (does one exist, or does a generic one exist)?
  • 6,487 Answers
The best way to extend a wireless signal is to get a wireless range expander/extender , because a high gain antenna really give the needed boost of wireless signal.....
Don't forget to rate the solution FIXYA thank you............
Posted on Oct 22, 2008
How can I use It wider range? ( not to extend another apple router but antenna or setup )
The airport routers have built in antennas and external antennas cannot be attached. For wider range, place the router high up and away from glass, metal, and stone. Try changing wireless channels to lessen interference.
Aug 04, 2013 | Apple AirPort Extreme Router
Tip
Boost wi-fi signals!!!
It is true that a direct cabled connection is probably faster, but that doesn't mean you can't get great Internet connection speeds from a WiFi connection. WiFi is a signal, so it's simply a matter of boosting that signal to extend as far as you need it to, and doing it in a way so you'll still get the same amount of power. There are ways to extend your WiFi signal, and most of them won't cost a penny. Here are my ten ways to boost your wifi signal:
  1. Position The Router - Yes, where you place your router does matter. If your wireless desktop or laptop is in another room, the signal has to go through walls and other interference before it reaches you. You can change the positioning and give everyone equal access. For example, in an open office room setting, instead of placing the router in a corner, try putting it in the middle of the room. It might give better coverage to the entire office. The signal should extend out more evenly. If you're looking for optimal wireless coverage in various parts of your home, position the router in the middle of the house. Moving it up off the floor, to a bookcase or shelf, should also help. If you only have one wireless computer, and it's always in the same place (ie: your office, the kitchen, or the hammock) then it makes more sense to place the router closer to the computer, rather than in the center of the house. But experiment -- I've heard of cases where there was a very weak signal, and the problem was that the router was TOO close to the computer.
  2. Avoid Bad Neighbors - Remember, wifi is a radio signal, so the signals from microwave ovens, cordless phones and even your neighbor's wireless router may interfere. So try to steer clear of those as well.
  3. Extend the Antenna - There are some decent booster antennas out there that you can purchase in addition to your current router to help the signal extend out further. You just plug them directly into the router base and it can give you that boost in the signal that you need. Hawking makes several types of wireless antenna boosters.
  4. Repeaters - This little gizmo just takes in the wireless signal, boosts it up to full strength, and spits it back out again. Place the repeater within range of the router, and near the computer that needs a wireless signal. Linksys and D-link offer wireless repeaters, also called range extenders. If you have an Apple computer, look into the Airport Express as a signal repeater.
  5. Gettin' Geeky - Some DIY geeks have come up with interesting ways to extend or boost your Wi Fi signal. One example is the Pringle Cantenna method. This may seem like a hoax, but the technique appeared in an O'Reilly book titled Building Wireless Community Networks, Nov. 2001. Other techniques, such as the satellite dish using a cellphone are elaborate hoaxes, and I'll admit I fell for this one before a kind reader set me straight.
  6. Upgrade Your Router - If you've owned the same router for several years, it might be good to go pick up a new one if you want to expand your connection. Some of the latest models have a stronger signal. The newer 802.11n routers generally have a stronger broadcast signal, and they'll work even if you have an 802.11B or G adapter in your computer.
  7. Upgrade Your Software - One of the most basic things you can do is to make sure your router software is up to date. To do this, visit the website of the maker of your router, whether it is Linksys, D-Link, or some other brand. Check for your model number and make any updates necessary.
  8. Tweak Your Settings - Your software has special features that you may or may not want. Make sure you read the manual that comes with your router and tweak it to fit your needs. Most modern ones are "just plug it in" though there might be ways to boost signals or to make sure it is sending out signals that are optimized for your computer's wireless adapter. For example, most routers are set to broadcast on channel 6. Try switching the channel to 1 or 11 and see if it makes a difference.
  9. Is Your Wireless Router Secured? - Make sure your neighbor isn't hogging all the juice from YOUR wireless router. Get your network secured only you are using the signal. Tap into your security features and make sure you use secure passwords. See wireless security for help with this.
  10. Find Alternative Firmware - While your router's original software (aka firmware) should be all you need, some routers do not output the signal at the maximum possible strength. You might want to check into alternative firmware, like OpenWRT. But be careful with firmware updates -- if you load the wrong code for your router, you can foul it up with no recourse.
on Jul 20, 2010 | Computers & Internet
If i was to plug any of the d-units in as a router to my 2wire wud i get a better signal
no necessary ! if you need to extend the range you can get different compatible antenna which can do that work for you should you need any help please contact me on http://computernetworksupportindubai.com/
Jul 25, 2011 | D-Link DIR-615 Wireless Router
I want to attch higher gain antenna to my Linksys router WRT54N. My existing antenna is not the detachable type. What should I do?
I believe you are trying to strengthen the signal of your wireless router. Unfortunately replacing the antenna does not work for these types of devices. What you need is a repeater. This will repeat the signal of your router and is typically installed farther from the router so that you will be able to extend the signal and reach places your router is not normally able to reach. If I may recommend a device, try this one out: Jefa Tech Long Range Wifi Repeater Kit. Check our the link to know more about the specification. According to the link, it can handle both wireless g and n.
Jul 08, 2011 | Computers & Internet
I want to extend the antenna on my d-link router. Reason: My computer shop is metal building, wireless signal is weak. As long as I don't short extension cable is this ok?
Instead of removing the antenna from the router you can buy a cheap working second hand router in market (better buy a second hand belkin router, because belkin provides free lifetime phone support also free lifetime hardware support for certain routers whose model numbers starts with F5D or F6D....Dont buy any belkin routers with model number that starts with F7D)
Now configure the second router as an ACCESS POINT (you can call 18002235546 to get help to change to an access point)
run a long ethernet cable from dlink router to the second router (belkin)... you can place the belkin router anywhere where the cable can reach...
The belkin router will broadcast the signal and you will get better signal strength...
Feb 03, 2011 | D-Link Computers & Internet
Can i add an outdoor antenna to my belkin f5d8236? how? do I connect to one of the existing antenna leads and forgoe the other? Do i need two outdoor antennas connected to it? I am trying to connect to...
I think you can try:
  1. Homemade Pringles antenna - Eat a packet of Pringles (ready salted would be my choice) then follow this tutorial to convert it into a functioning directional antenna. Point it where you need a signal boost.
  2. Airport Express & kitchen sieve - Take an Airport Express and set it into a common metallic kitchen sieve to boost it's signal further.
  3. Try a parabolic dish - Hawking make a 802.11 B/G parabolic dish that basically pulls in a WiFi signal, performs some magic and boosts your range by up to 300%! It only costs $80 and it has a cool retro style.
  4. Cantenna - This is basically a pro version of the Pringles tin hack. For $50 you can buy a Cantenna that plugs into your router and extends your WiFi signal. It also looks cool.
Also see this:
The Wi-Fire uses a powerful directional antenna, highly sensitive receiver and proprietary software to find and enhance normal WiFi signals. With it, you can connect wirelessly to the Internet-even at low signal strengths-faster, more reliably and with a more consistently strong connection-than you are able to with an internal wireless adapter.
The Wi-Fire draws very little power from your laptop battery. It comes complete with everything you need to connect wirelessly to the Internet. Just install the Wi-Fire Connection Manager, plug the Wi-Fire into an available USB port and you're ready to start. It can rest on any flat surface, laptop display or flat screen monitor.
Dec 31, 2010 | Belkin F5D8236-4 Router
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
I have a 2wire Gateway modem/router. I would like to extend the range by 75 feet to reach an outbuilding i use for an office. What can I do?
A couple of ideas come to mind, but basically 75 extra feet could be a problem. It's unlikely that you will be able to extend the range of your present router, but that's the first place to look. The antenna may have a mini-connector on it that unscrews. You can add a 5 or 9 dB antenna to the base unit and push the signal farther.
The problem you face is you might be able to see the signal, but you still can't talk back to it. There are instructions floating around the internet to convert a wireless router to a wireless bridge. A bigger antenna at the Gateway and a router wired as a bridge would get you all the signal as a point-to-point system.
Of course, an industry standard wireless access point, will have a bridge mode. Again, it might be enough to just get one of those and it will be able to communicate with your existing equipment without adding the high gain antenna.
A typical WAP with antenna is in the neighborhood of $90.
Carl
Sep 10, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Extending range of wrt54g router
yes there is a way to extend the range. it involves flashing a 3rd party firmware into your router. another way is to buy better antennas for it. radio shack has a pair for your router that are made by gigaware that will add 7dBi to your range. That is an easier solution. if your want to try flashing your router (my personal favorite way), then let me know and i will walk you through on how to do it. ; )
Apr 23, 2008 | D-Link 2.4GHz Wireless g Laptop PCMCIA...
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
430 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Jaspreet Saini
Level 1 Expert
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
