Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP L7555 My HP L7555 is printing backwards. Any ideas?
REads remove and check cartridge
Posted on Oct 19, 2008
How to fix when printer print letters cut at the bottom
Go online to HP and download the latest driver updates. Install them. Try printing again. If that takes care of the problem fine.
If that doesn't work your toner cartridge may be low. Try putting in a new one and see if that takes care of the problem
If neither of those work, and If you know somebody who will lend you a printer and the necessary drivers, install the drivers, and try printing with that printer. If the problem persists then the is your computer. However I don't think that's what's going to happen. HP used to make high quality printers - now they don't. I had to junk one after a year.
Drivers first - they're free! Toner cartridge second.
Aug 27, 2014 | HP Ink for OfficeJet Pro L7555
HP Officejet Pro L7555 will not print black ink
Replace print head(black & yellow) or try to clean the nozzle.(try youtube videos for cleaning)
May 19, 2014 | HP OfficeJet Office Equipment & Supplies
My HP Officejet L7555 will not scan to my Notebook Laptop problem. I have tried to download HP Solutions Center wiyh no success. When "Scan" or "Start scan" is depressed on my L7555 printer, the printer...
How is the HP Officejet Pro L7555 connected to the computer? Can you manually launch a scan from the computer using the HP software?
If you can start a scan from the software, you may need to set the software to listen and respond to the all-in-one's buttons. In Settings, choose Scan Settings. In this menu, select Scan To Setup. Add the needed buttons. Click Update device and set the scan quality/destinations. Save this. If these short-cuts are available in the HP Solution Center, check if the monitoring software is set to run automatically. If the monitor is closed, you will need to launch it.
If you can't launch a scan from the software manually, then your computer and the all-in-one are not communicating properly. Scanning requires bi-directional communication. If the connection involves a USB cable, try a new cable. Try a direct connection if you are using a USB hub. For a network connection, check your firewall (inbound and outbound traffic). Resetting the firewall will depend on that software. Check that you have the current drivers. Consider using the HP diagnostic software to check for problems.
I hope this helps.
Mar 05, 2018 | Computers & Internet
Where do I find the driver download for my printer hp l7555 . I am changing laptops and lost my printer disk.
Jun 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Prinitng backwards
Try this....
Turn off mirror imaging in Printer Preferences . To do this, use the following steps:
  1. From the Windows taskbar, click Start and then click Run .
  2. Type control printers in the Open box and then press Enter . The Printers and Faxes window displays.
  3. Right-click the HP product from the list of printers and then select Properties . The Properties dialog box displays.
  4. From the General tab, click Printing Preferences . The Printing Preferences dialog box displays.
  5. Click the Advanced tab.
  6. Under Printer Features , click Mirror Image , click the down arrow (c01320592.gif ) to the right of the field, and then click Off .
  7. Click OK to apply the change.
Dec 22, 2008 | HP Officejet J5780 All-In-One InkJet...
HP L7555
When you select "Print" and get the print window to "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
316 people viewed this question
Ben Johnson
