Question about HP LaserJet 1100 Printer
Hp laserjet 1100 printer doesnt work
The gears in the printer dont even move when i turn it on. the lights blink though, they end up on the attention LED.
how do i even open this printer. it seems so complicated.
help.
To open printer you need to remove screws. then two gray plastics parts on sides. cover on back should be removed then. front cover is similar, but front door first - unplug cover from two plastic sticks on top, then remove screw on bottom in hinges. be careful about wires.
Posted on Nov 18, 2008
HP LaserJetM551
Turn printer off and unplug any network or usb cables. Restart printer, if it comes to ready then you may only need to update the firmware on the printer to solve your problem. Go to HP.com and download the current firmware for the 551 and copy it to a USB stick. In the menus on the printer go to Printer maintenance>upgrade firmware and then insert the usb key into the usb slot on top of printer. Screen will show the file that is on the usb key, press ok and wait for process to finish.
Aug 11, 2014 | HP LaserJet M551 M551N Laser Printer - C
Hp laserjet 1320
Go To Below official HPPrinter Page For Your problem, HP Support document Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1320 Printer
Error 57.03 on Hp Laserjet printer P 3015
Fan FM2 not working or jammed.location: remove left side door. you can see the fan..If jammed make it free, if its not working replace it.
Jul 06, 2011 | HP LaserJet P3005n Printer
Dont have cd printer hp laserjet 1100
If you do not want to order a replacement CD, why not download the printer software for your model from HP: (choose your language and operating system)
HP LaserJet 1100 Downloads
Jan 02, 2010 | HP LaserJet 1100 Printer
Paper gets stuck
Remove toner from printer and check in side area one gray color roller will be there with blue lock remove roller
clean the gray pickup roller and check if its get smooth its need to be replaced
place 5-10 paper and check for prints if it’s picked properly
Nov 08, 2009 | HP LaserJet 1100 Printer
The orange light keeps blinking and won't go back
This could be signaling that the toner is empty. Replace the toner and see if the light goes back to green. Hope this helps.
Oct 16, 2009 | HP LaserJet 1100 Printer
My hp laserjet 1100 doesnt respond when i try to print
Not sure if this will help but if you right click on the printer and go to properties ( when your in printers and faxes ) and go to the ports tab I think it is and un tick the check box that says bi directional support and try it again.
Also what error are you getting thats printed off ?
what lights are on the printer and where are you getting the driver from, if the disc then try the latest driver from the hp website
Apr 22, 2009 | HP LaserJet 1100 Printer
Lj 1300 doesnt spin up just blinking bottom yellow light
My guess is that the wire from the photocell at the rear of the fuser (exit sensor) is not seated properly. The connector on the board side also has a nasty habit of the pins pushing down into the board in the connector. Put check the connections carefully from the exit sensor to the main boad. If it has pushed down, it can be pulled back up without ill effects using a small pair of hemostats..
Let me know what you find. Hope that helps you.
Aug 25, 2008 | HP LaserJet 1300 Printer
Flashing red button with a triangle and ! in it . printer won't work
If only the attention light is flashing then follow the guide below -
The Attention (amber)
light is blinking.
Attention error. The top
cover is open.
Close the top cover.
printer is out of media.
Load media.
printer has a jam.
1. Clear the jam (see pages 164 through 168).
2. If the location of the jam is not apparent, check
the embedded Web server to find the jam
location.
 If the jam was under the imaging drum, toggle
the registration sensor to check its movement
and replace the registration sensor if it does not
move freely.
 If the jam was in the fuser area, toggle the fuser
exit sensor to check its movement and replace
the fuser exit sensor if it does not move freely.
Jun 07, 2008 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 1100 Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
