Question about JVC FS-SD990 CD Shelf System
Power will not stay on
I have a JVC FS-SD990, when I push power it starts to
power up, lights flash then it turns back off. The clock
flashes as it stays in the plug in the wall mode. Any suggestions?
I have heard that it could be a fuse, but where would that be located?
Thanks!
joshy999
  • 241 Answers
SOURCE: JVC Model AV-36D502 Blinking power light on start-up
you probably have some sort of overheating or short on the internal board - is it still on warranty? if so they will fix at no charge - if not, a local repair shop should be able to correct the problem but it may cost as much as $150
Posted on Jan 26, 2008
SOURCE: JVC HR-S9500U
OK, found the problem. Another website had the same question on the HR-S9600U, the 9500's replacement:
http://www.cippico.com/bbs/viewtopic.php?p=528&sid=ce3dfc944e4539181195720b836021f4
I checked my vcr, and, sure enough, there was a sort of clicking sound coming from the drum area immediately before the unit would go into "Auto" mode. I removed the complete drum assembly, and tore into the little gearbox, and found the two black, plastic gears with inside pinions that drive the metal screws to change the video head position had each cracked and were slipping on the shafts. This caused the gearbox to bind up.
Using a jeweler's screwdriver, I roughed up the metal shaft and the inside of the gears where they slip onto the shafts, and glued them on using a two-part epoxy. I then re-assembled it all, sorta setting the screws about two turns after their contact with the base of the upper drum. Now, upon power-up, the drum adjusting motor toggles one direction, then the other, and the unit stays on. Playback seems OK.
So, there you go. Yay me....
Posted on Dec 28, 2008
Benimur
  • 6966 Answers
SOURCE: JVC 36" TV will not power on and has a blinking power light...
Hi and welcome to FixYa,
Almost always, when an electronic device/equipment fails when powered with and by a generator, it is the power supply unit (PSU). The PSU circuitry expects a fairly constant/stable power source (120 or 220). The output of the generator tends to fluctuate especially under varying electrical load. Additionally, the AC frequency (60Hz) of the generator's output also tend to vary which most PSUs don't like. A noteworthy point to consider is that the generator is floating electrically, its output has no reference to earth/ground.
If you are considering a DIY (do-it-yourself), foremost to inspect would be the PSU particularly the regulator transistor and determine if it outputs +5 and ~+135 VDC. Another to check would be the HOT (horizontal output transistor). If when the TV was used powered by a generator, there was considerable vertical rolling, the vertical deflection IC would also be a suspect.
A friendly reminder, exercise caution when repairing TVs. It stores up EHV (extremely high voltage). It would be to your advantage to reference a service manual (JVC AV-36D303) or at the very least a schematic diagram with voltage readings.
Good luck and Thank you for using FixYa.
Posted on Jan 05, 2009
  • 132 Answers
SOURCE: JVC tV D series will not turn on when I hit power
Hi There,
Did you try turning it on from the actual TV power button?
Posted on Mar 29, 2009
  • 105 Answers
SOURCE: my tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Posted on Apr 29, 2009
My lg washer when pushing power on , cl starts flashing on the clock. Washer will not start.
this usually means that the child lock is activated. it is usually deactivated by pressing two buttons together, this should be mentioned in your instruction manual.
Oct 07, 2016 | LG Washing Machines
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
JVC black screen power light blinking
Flashing standby light at the front panel indicates a fault in the internal circuit. Count the number of flashes occurs at one time. Visit the site linked below to get more details about the blinking codes and fault locating. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 27, 2012 | JVC LT42X579 42-Inch 1080p LCD HDTV
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
HOW DO I SET CLOCK
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
AM
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
PM
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Regards
Mike
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
My tv won"t turn on.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Not printing the correct text / picture
your in line mode instead of page mode.
  1. Turn printer power off.
  2. Press and hold the feed key, then turn power back on.
  3. When light starts to flash, release finger from feed key.
  4. When light starts to flash again, press and hold the feed key until the light turns red (or amber), then release finger from feed key.
  5. Wait for light to turn solid and press feed key once.
  6. Check to make sure you are in the correct printer mode by printing a configuration label (Click here for configuration label example - Note item C).
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
JVC FS-SD990 CD Shelf System Logo
20 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
