Question about Philips Magnavox 27MS343S 27" TV
Channel display How do I set my 27 inch Phillips TV To display channels as I am changing them?
  • Philips Master
  • 520 Answers
Here's a link to your owners manual if you need it. I'm sorry but I didn't see anything other than pressing the display button to see what channel your on.
http://www.m4c.magnavox.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Posted on Oct 17, 2008
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
How do i channel scan on a phillips tv without remote control
Feb 18, 2015 | Philips 32PFL3403D/27 32 in. LCD TV
Cannot get a signal on my phillips t.v. iput and antenna n zenith digital converter box n say`s no signal
Hi. Convertor boxes have a preset channel output. This is either in the VHF region (channel 4) or somewhere in the UHF region (like most video's on channel 36 or 38). Switch on the convertor, and try a scan on your TV. You must be able to locate the output channel from the convertor. At least if this one is ok, or receiving.
Oct 05, 2014 | Televison & Video
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
Sony Trinitiron 27 inch. It's stuck on channel 27
go to menu then channel turn off channel fix that might help ya
May 24, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Phillips TV/VCR combi 14PV400/07
To solve this problem, cancel the wake up alarm !
Dec 23, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Philips TV set PC7225-PC121
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Aug 04, 2007 | Philips 25PS40S 25" TV
Channels change without changing channels!
check the tv system control the ic is probably bad have a tech check tv and make the repairs good luck.
Dec 21, 2006 | Sanyo AVM-2759S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
