Question about Hitachi 61SWX12B 61" Rear Projection Television
Convergence on Hitachi 61swx12b
Convergence after replace ic's off.(resistors read good onot open or change values.
Thank you
mpadi
  • 61 Answers
Check what is happening when you press flash focus?It completes 1 full cycle or not?
If not complete 1 full cycle check small value resistors on convergence board.All RK series resisitors..
Dont Forget to Rate!
Good Luck
Dals123
Posted on Oct 17, 2008
Hitachi 61swx10b HDTV - Convergence problems. User 'gdroukas' mentioned in a post that it is probably the convergence amps and a few resistors that have changed value. Can anyone be a bit more specific? ...
Convergence ICs are Big Black ICs and will have the part number on them. STK392-110,
upgrade to 120s or 150s better ICs.
Resistors to replace are RK42 3.3ohms, RK46 1.8 ohms, RK50 2.7ohms,RK54 1.5, RK58 3.9 ohms. RK62 2.2ohms
Mats Electronics has STK ICs 1-800-628-1118 order convergence Kit that comes with resistors.
ACME has the Convergence resistors they must be 1 watt resistors 1-800-575-9833
Let me know if you need any more help Thank You.
Jan 13, 2011 | Televison & Video
I have a hitachi 43FDX15B RPTV It appears to have a convergence problem, I've read about replacing the stk IC's but which resistors need to be replaced and what are the values on the DP15k/08 Board?
This model uses two of the STK-392-120 CHIPS and here are most of the usual resistors to suspect or check:
Hitachi AT03411S RK43 RESISTOR Hitachi AT03608S RP22 RESISTOR Hitachi AT03195S RK46,RK54, RK62 RESISTOR, 1.8OHM 1W Hitachi AT03857M R815,R865 RESISTOR, 1/2W 100 OHM Hitachi AT03191S RK50 RESISTOR, 1W 1.2 OHM Hitachi AT03197S RK50 RESISTOR, 1W 2.2 OHM Hitachi AT03199S RK41 RESISTOR, 2.7 OHM 1W Hitachi AT03202S RK42 RESISTOR, 3.3OHM 1W Hitachi AT03204S RK58 RESISTOR, 3.9 OHM 1 WATTThe RK ones are all marked on top and bottom of circuit board---usually if one is bad you will be able to see it is discolored---all are very low value and should read open or good only.
This is a fairly easy set to do this on---the whole convergence board (right side from the back view) is held in with 3 screws and an assortment of plugs--3 plugs are identical (convergence yokes and you need to mark so you get each back in same place)
A row of black snap plugs on the left side and with the screws and other plugs removed the board will lift up and out of the set.
DON'T waste your money on one of the "kits" being sold on the net---you can buy a pair of the chips for about 12 dollars on Ebay and usually only one (if any) of the resistors will be bad---those kits sound like a good idea but at 50-80 you are buying things you will not likely need to repair the set.
Let me know if you have any questions and if this information helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Looks like I have extra blue and yellow lines abow the image on my Hitachi 61SWX12B 61 in , just started today ?
If you go into the customer menu and select convergence and red or blue are skewed and will not adjust---you have a convergence circuit problem.
61SWX12B uses two of the STK-392-110 convergence IC chips. Both chips and any bad protect resistors around them need to be replaced and the set adjusted with the Hitachi remote.
Most of the time just both chips need to be replaced and the set adjusted.
Considering you can buy all the parts needed for under 30 dollars on Ebay if you or someone you know can do this repair you can save a lot of money--most shops are going to get 300 or more. I can give you general instructions and tell you the best seller to get the chips from on Ebay---I buy the ones I use there.
Let me know if you have questions or need advice-I am here to help people.
If this information has helped you rate this solution as I do this here FOR FREE.
SD TECH.
Nov 27, 2009 | Hitachi 61SWX12B 61" Rear Projection...
Hitachi 61UWX10BA RPTV Convergence Repair
All of the resistors that fail are very low reading ones---like RK54(1.5 OHM-1 WATT) RK50(2.2 OHM 1 WATT) AND RK58(2.7 OHM 1 WATT)
These are not large resistors--all have location numbers on top of the board under them---most of the protection ones will begin with RK----check them like a fuse--they rarely go off value and if no reading across them they are bad---
There will be some higher value resistors like 150 or 220 ohm----never seen one of those bad.
Sometimes you just have to check them all and if they are good replace the chips and see what you have.
Do not forget to apply heat sink compound to the new chips before you install them(remove any old grease first from the heat sink.)
Good soldering is important here.
SD TECH
Oct 28, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Color convergence problem
Follow the traces on the PC board from the ICs and you should find either pico fuses marked as Fxxx on the board or low valued resistors that may appear to be a bit burned. Some of those parts may be defective. These are the "feed" resistors or fuses for the power to the ICs. The low valued resistors are current limiting resistors that act like fuses. If any of those are open, the convergence ICs won't function properly.
Dan
Feb 16, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 53uwx10b
I believe you can order the convergence board replacement for $299 from Part Store, here's a link to it for my 61" Hitachi, which should use the same board:
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/61SWX12B/Hitachi+Ltd/Hitachi/CS00452R/New.aspx
They offer a 30 day hassle-free return policy, so if for some reason it wouldn't work for you or isn't the right part, all you'd be out is the return shipping, as the initial shipping is free.
I'm in the process of having my board fixed w/the IC/resistor kit and hopefully I don't need a whole new board.  We'll see, but give this a shot, I don't see how you can lose...  -TD
Mar 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Re: 43FDX01B blue convergence issues
Ditto CTF1800's comment....Check RP-41 1.5 ohm 2 watt and
other low value resistors near IC's mounted on large heatsinks.
STK392-110 original convergence IC's can be upgraded to
Hitachi # CZ 01341 new number STK394-160E for greater reliability.......Hitachi also has an IC / resistor kit # X480295,
but I don't change good resistors, only the bad one(s).
Practice good visual acuity technique and ask questions!.....T.
Jan 02, 2008 | Hitachi 43FDX01B TV
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Colors all messed up
The fact that you used the term "magic focus" tells me you have a Hitachi projection set. When the colors no longer line up on a Hitachi projection TV, it means that most likely one of the convergence output IC's has shorted out. Sometimes a shorted convergence output IC will burn up a low value resistor too. I have also seen a convergence IC crack loose from the board and burn up 3 low-value resistors. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The output IC's should be resoldered / replaced and the circuits checked and realigned by a qualified tech familiar with Hitachi projection sets.
Sep 09, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Convergence problems?
While the OP may no longer have this issue, I'll comment on anyone else that may come across this.
In addition to the suggestion of replacing the ICs above by Leadtech, the resistors also should be changed at the same time.  Quite often, even if a single IC or both are replaced and the resistors are not, the issue will re-appear.  There are a few locations selling a kit in the $50 range, so the difference for the additional resistors is minimal.
As for the sound issues, several owners of this and other Hitachi RPTVs in this line have had issues with their sound boards, which seem to be largely a defective product.  Even replacement of these have resulted in the problem re-occurring at a later time.  I would suggest using an external receiver and speakers as it may not be worth the time and money to repair this problem.  -TD
Jan 26, 2007 | Hitachi 61SWX12B 61" Rear Projection...
Hitachi 61SWX12B 61" Rear Projection Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
