Question about Samsung SF-5100 Plain Paper Laser Fax
Toner Did you ever get a solution regarding the problem you're having with your fax and not printing even when you replaced the toner? I have the same problem. Can you help? Thx.
  • 161 Answers
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Be blessed.
Posted on Nov 07, 2008
How do i reset toshiba estudio 181 printer if the replace toner light keeps staying lid even when i put a new toner
Is nothing to reset, you must verify if the toner sensor is not dirt with toner. Best regards,
Dec 06, 2014 | Toshiba OEM ESTUDIO181 18 CPM/PPM...
Just replaced drum and toner and now faxes don'y
if your toner and drum have been at an angle , toner will only be on the left side.
here's the fix.  Remove drum cartridgewith toner in it and move it gently from extreme right to extreme left, do this three times and your image should be ok
Aug 13, 2009 | OKIFAX 2600 Fax
Verical lines of inconsistent or un-even printing,
In almost every case, the problem you describe can be traced back to 2 things. Dirty corona wire or dirty drum (or both). Pull out the toner cartridge, slide the wire cleaner back and forth a few times, clean the drum. The gently shake the toner cartridge from side to side to evenly distribute the toner and replace. This should solve your problem. Best of luck.
Greg
Jun 21, 2009 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Received fax in memory but not printing
I just checked this out as I had the same problem. It seems that the machine is programmed to stop printing faxes when the Toner is "out". Even though the toner is not completely out. I was positive that the note on the screen was false since I could print out documents and copies (I am not using Samsung original Toner). But the fax will refuse to print.  I fixed this by changing the toner (again with a non-Samsung toner) and it is printing all the faxes in memory.  It is stupid that they haven't set up a menu item to force it to print all the faxes in memory but voila, that seems to be the fix. I guess this is a way for them to control that we only use Samsung toner.
Dec 12, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Toner
Now, if the unit does not clear the "Toner" error, you might be using a compatible toner that might not be as compatible as it should be. However , if the new toner is Samsung original, let me know for there might be another solution.
Be blessed.
Oct 16, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SF-5100 Plain Paper Laser Fax Logo
42 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
