Question about Kenwood Car Audio & Video
The radio unit I have a problem with is a Kenwood. It is a 'factory installed option' on a 1987 Honda Helix motorcycle. I believe the model is a KRM-100H. The radio was called a HondaLine Kenwood, but several people have told me that the 'KRM-100H' is the model designation. This unit has remote controls (wired) volume, tuning, and band selection. No power on/off on the remote control panel. This radio works! However, the push button power on/off button will not stay 'in' when depressed, so the unit only will function if the power button is depressed and held in. The face of the unit is encased in a plyable plastic cover for weather sealing. I would like to repair this unit if I can on my own, however I am not all that versed in electronics but I am not afraid to tackle a repair if it is a fairly simple matter and I would not be risking further damage.
5 Suggested Answers
  • 10 Answers
SOURCE: model krc 777r car stereo
sounds like the ribbon cable has gone out to the controls. can be repared but really not worth it
Posted on May 29, 2008
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
keemo68
  • 1263 Answers
SOURCE: I have a 1997 BMW
in most cases it's often more costly to repair it than to replace it. the only way you can save costs on repair is if you do the work yourself or have a buddy that knows how to do it, otherwise the labor costs are just not worth it. please rate this
Posted on Sep 28, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a Mustang GT
a savvy installer can make a circuit using your garage remote (installed in the dash) or some wireless lights (with remote) and with the push of a button, your (insert item here) will function.
Depending on the voltage required, one is really just a ground, and the other is a positive trigger.
It requires a SPDT relay, and if the remote is not 12V, a resistor of the right value to lower the voltage.
Posted on Jan 14, 2009
  • 18 Answers
SOURCE: replacement Kenwood KSC-WA82RC Car Subwoofer remote control wire
It looks like the S-video you need one end to be male and the other is female end.The high quality the S-video wire the better the sound.Make sure you get a long enough cord. Take it with you to radio shack or and car audio or home audio find the female end of the S-Video and it should plug in perfect.Wire it up and enjoy some tunes
Posted on Mar 03, 2009
Just bought a 1987 Honda gold wing 1200 and the radio wasn't working. So I pulled it out, it was disconnected. The radio works fine, but now I can't get it back in the dash. Is there a secret? Really tight...
Hi, Debbie try using silicone spray on the radio edges and the dash insert opening for this scenario you will need your service/owners manual/wiring diagram if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
GL1200 radio install
Honda Goldwing GL1200 Aspencade Stereo Install 2015
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL 1200 84 Aspencade Parts Manual
Honda GL1200 Aspencade Owner Manual
Feb 11, 2017 | 1987 Honda GL 1200 Aspencade Gold Wing
I have a Kenwood RX370 in a 2001 Honda Fit. I'm trying to put in AUX mode!
Hi,if the input jack isn't in the radio face, your unit probably isn't aux equipped. The only input would be in the back of the deck, which would require you remove the unit and look for the aux input there. Hope that helps.
Oct 11, 2016 | Kenwood Car Audio & Video
Fuel pump pressure
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your Honda but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2006+honda+helix+250
Nov 22, 2013 | 2006 Honda Helix
1986 helix, only 4 volts on red wire going to ignition switch, nothing happens when key is turned to on and starter switch is pressed.
Hi Anonymous, you may have a failed battery cell in which case it needs to be replaced and I am sorry you can't find the first and best tool you ever bought for your Honda but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/1986+honda+helix
Aug 05, 2013 | 2006 Honda Helix
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
I have a fuel pump problem with my Helix. I first misdiagnosed it as the fuel pump itself. After electrically connecting up a known good pump I switched on the ignition with no results. I tested bo
Hi Harry, I am sorry you can't find the first and best tool you ever bought for your Honda but despair not for a mere $15.00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Honda Motorcycle Service Repair Workshop Manuals
Oct 10, 2012 | Honda Motorcycles
Hi, I would like to install my kenwood kdc-w7534u into my mini one, how can I do it, can you help please?
To install your kenwood, you will need to first remove your stock radio. To do this, I believe there is a screw you can get at from the glove box. As well, there should be trim around the radio itself. Pry into that, and pull as hard as you can. It should pull off the trim-- from there, you should be able to remove the original radio.
While putting in your new head unit, make sure you have the right wiring harness. With this, you can plug existing wires into the new receiver. From there, all you need to do is make sure all of the previously installed wires are installed in the new unit correctly, then secure the unit and replace the trim.
Voila, you're done!
Feb 28, 2011 | Kenwood Car Audio & Video
I put in a NEW RADIO IT'S A KENWOOD BUT THERE'S NO SOUND TO THE SPEAKERS .RADIO TURNS ON AND EVERYTHING WRKS BUT NO SOUND.
Check the original wire harness to find the power wire for the factory installed amplifier. Hook the antenna/accessory wire from the new Kenwood unit to it to trigger the factory amp. I'm going to take a stab in the dark and say it's a Jeep Grand Cherokee ant the amplifier is under the rear seat. That information (model and Year) would have helped. Please rate my assistance and leave a testimonial to assist others.
Jan 01, 2011 | Jeep Car Audio & Video
Have a 1987 xl600r do not get any spark to the plug
Its probably the coil i believe its right under the gas tank on that model of bike.
Sep 04, 2009 | 1987 Honda XR 600 R
I need wiring diagram for Kenwood kdc-mp228 radio
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/
Just input your model number in the third search field, download the user manual, then look on page 25 for wiring connections. Hope this helps.
Aug 23, 2009 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
289 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
