Question about Sony Playstation 3 (PS3) Console
Jammed game removal
Power supply bad....
BEFORE returning to sony, is there a way to remove the game inside?
  • johntowers_2 Dec 27, 2008
    my son pressed the power button to restart it for no reason while the game was still inside. and now the game wont eject and it makes loud clicking sounds while it tries to eject.
  • 98 Answers
You can just take the ps3 apart, im sure its scary but hey you would get your game out.
Posted on Oct 17, 2008
Di2010f code C004E
Power unit cooling fan is bad or jammed with dust!. looking at the rear of the machine on the right side lower there is a vent. remove the back panel (will require removing the upper back panel also. There is a filter with that motor. it mite be jammed in the fan clean it and tape it to the metal cover or just remove it then will have to check on every once in while. That fan cools the Power supply inside the machine. Might be burn it out worse case the control board that controls it is bad.
May 21, 2013 | Minolta DI-2010F Copier
I was about to remove game from my ps3. The power went off for a few seconds at the same moment I tried to remove it. Now my ps3 will not come on or remove the game. any suggestions.
Unplug everything and let it sit for a few minutes. Then plug it back in.
If it still doesn't work, it is probably just a bad power supply. See if you can borrow a friends power supply and test your ps3 with it. If it turns on then go buy a new power supply.
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
When itry2 turn on my ps3 it turns off no red 2 green it just powers down got to unplug 2 even try a differnt way only 9 mon old didnt get xx warrenty should i try 2 return
Hello
It sounds like your power supply is bad.Check the connections on the power supply .
If this continues get a new power supply.
Oct 02, 2011 | Sony Playstation 3 (PS3) Console
My psp unable to start up after showing the sony logo.. it stuck on the blue screen.. i try to go to recovery mode and reset the psp.. and it doesn't work neither.
REMOVE THE MEMORY STICK, REMOVE ANY UMD GAME INSIDE, REMOVE THE BATTERY,
PLUG ONLY THE POWER SUPPLY TO THE PSP
NOW TURN IT ON
IF IT WORKS, TRY TO PUT THE THING YOU REMOVE BACK ONE BY ONE
YOU WILL FIND OUT WHAT CAUSED THE PROBLEM
IF THIS DIDN'T WORK, YOU KNOW THAT YOU TRIED TO HACK YOUR PSP
AND YOU BRICKED IT.
PLEASE RATE IF THIS HELPED YOU
Apr 11, 2011 | Sony PlayStation Portable (PSP) Slim...
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
What is a carriage jam
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
May 10, 2010 | Office Equipment & Supplies
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 03, 2008 | Office Equipment & Supplies
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
