Question about Kenmore 24032\24036 Top Load Washer
Lwd70aw washing machine water pump
I can not remove water pump from motor shaft. The motor and pump are removed from the machine and the three torq screws are also removed.
  • Bill Newberry
    Bill Newberry May 11, 2010
    If you could post the model number to your machine, I will be more than happy to help you out.
    Thanks,
    Bill
    Sergeant:
    Champion:
  • 291 Answers
Your pump been leaking water and has the pump rusted to it ,,,,, if the clips are removed the you will just have to pry and break pump loose to remover ,,,, clean the motor shaft good before installing new pump
Posted on Nov 25, 2008
Wash machine runs fills with water drains but will not spin to wash or end of cycle but I do hear motor running
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Feb 08, 2011 | Kenmore 15864/15862 Top Load Washer
I HAVE A KENMORE SERIES 70 WASHING MACHINE. IT FILLS UP WITH WATER BUT WHEN IT GOES INTO WASH CYCLE, IT DOESN'T AGITATE, IT JUST MAKES A LOUD NOISE. IT WILL DRAIN WATER BUT DOESN'T SPIN. IT ONLY MAKES LOUD...
Jan 13, 2011 | Kenmore Washing Machines
Loaded with clothes and water, wouldn't start washing and started smoking.We unplugged it removed the clothes and waited until the next day ,turned it to the spin cycle plugged it in to release...
May 01, 2010 | Washing Machines
My washing machine wont wash or spin. it takes in water and drains water but the drum will not move.
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Mar 23, 2010 | Washing Machines
Belt removal for Amana washer model#LWD70AW
u have to wiggle pump from side to side and up and down shoul losen up and pull strsight out
Apr 11, 2009 | Amana ALW480DA Top Load Washer
Washing machine - Need to replace motor cupling on the kenmore 90 series
you have to access the coupling by removing the housing of the machine,
you can tilt it a little bit to the back so that the motor is in your front.
remove the water pump clamps so that you can remove the pump.
unscrew the screws holding the clamps of the motor.( hold the motor tight, it is heavy)
remove the clamps, the motor will fell..
remove the motor and you can see that the coupling is attached to its shaft.
one coupling goes to the shaft of the motor, the other coupling goes to gear box shafting, and the rubber ring is in between the two coupling.
normally, only one coupling is damaged and you can just replace that coupling. you have the other two parts as spare.
i hope this would solve your problem.
tnx 4using fixya,
drcool
Sep 11, 2008 | Kenmore 23822 Top Load Washer
Replacing belt on Amana LWD70AW top load washing machine
There is a post for this in my solved solutions. If you cant find it......amasuperbike@comcast.net
Jan 10, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine belt replacement
I found the exploded parts views for that model number branded as a Maytag. Look to see if the are the same on the link below:
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LWA60AW&mfgModelNum=PLWA60AW&fkMfgID=1
Use the parts diagrams as a reference.
Remove drain hoses, motor
Move motor inward while removing belt from pulley under tub
Three screws with star heads hold pump to motor and careful when removing pump--it could crack if it is frozen to motor shaft.
Jan 04, 2008 | Washing Machines
Roper ras8445KQO washer
arlenekc : The water pump needs replaced.
malibu66,: Replacing the pump is not difficult at all.
In the above cases, Tilt the machine back so you have access to the bottom. (It there is a soft bottom plate you will have to remove it.) The pump it located on the bottom of the motor and is held on by two clips. Remove the hoses ant then the clips. The pump should slide off the motor shaft. If the pump does not come off then you will have to break it off. DO NOT pry on the motor or shaft. Once the pump is off check the motor shaft for any rust or build-up. This will have to be removed before a new pump is installed.
Line the pump up to the motor shaft to get it in place and put the unit back together then check the operation.
LITTLEGIRL4 Open the lid and find the water flume where the water comes in. This flume gets out of position sometimes. Start filling the machine and watch the flume. If there is water dripping or running down the sides toward the rear then the flume is not in position or has been damaged.
Dec 25, 2007 | Roper RAS8445KQ Top Load Washer
How to remove pulley from pump?
Your question suggests you are trying to remove the pump pulley. This pulley is not removable. The motor pulley should have a set allen screw in it to release.
Sep 26, 2007 | Amana ALW480DA Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
154 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
