Question about HP PSC 1610 All-In-One InkJet Printer
Paper jam HP PSC 1610 Al-in-one I was trying to print a 4X6 photo and it jammed so far inside I can't get to the paper to unjam it. How can I open the printer?
  • 435 Answers
Hi Marybarron,
Please visit the below mentioned link, if you want to know:
How to fix the Paper Jam problem
Also, you will find the opening instructions on that page itself.
Thank You
Posted on Oct 20, 2008
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One paper jam 1/2 sheet
Throw this thing out as it is clearly rubbish. HP inkjet printers will **** the life and money out of you. Get a Brother HL-2170W and you will have care free printing for cheap.
Cheers old chap.
Mar 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper jams with photo paper only hp1610 all in one. will print photo on regular paper any size.machine also makes a "grinding rotating" noise
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
May 08, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Paper Jam HP 1350 All-In-One
The back of the HP psc 1350 DOES open! I got a 4x6 photo paper stuck too. After finding no help in the HP software manual, I accidently noticed that if you look closely at the back that grey area that looks like it should come off does! If you look closely you will see an arrow to the left of the gray panel. You can push right and pull toward you at the same time and the panel comes off where you can easily take out the stuck photo paper.
Nov 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
Paper jam
It's pretty rare to not be able to manually clear a paper jam. Occasionally, after you clear a jam, some paper gets stuck in the mechanism where your fingers can't reach. In that case, part of the printer mechanism needs to be taken apart to get to the jam. Like I said, it's pretty rare, but when it happens, your only option is to take the printer to a certified printer repair shop or back to the place where you bought it to get it worked on. Unless you know what you're doing, I wouldn't recommend using tools inside the printer yourself. You run the risk of damaging the mechanism and making your current problem worse.
The HP web site does publish a couple of solutions. Have a look at the information on the following two links and see if there's anything you may not have tried yet:
Clearing a Paper Jam
Clearing a Carriage Jam
Post back whether or not either of these links worked out for you. Good luck.
Oct 01, 2008 | HP PSC 1610 All-In-One InkJet Printer
Paper Jam
  1. Press the On button and then unplug the power cord.
  2. Press in the tab on the rear door to release the door. Remove the door by pulling it away from the unit.
  3. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  4. Replace the rear door. Gently push the door forward until it snaps into place.
  5. Plug the power cord in and then press the On button to turn the unit on.
  6. Press OK to continue the current job.
Aug 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer jam
hve u tried removing the paper jam from a proper place.hp has provided a door behind the printer to clear paper jam.open that door n check out 4 any paper part left out in it.wish u success
May 31, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Paper jams
Had this problem, too with HP PSC 1610 AIO, paper would pull in part way and stop, then display would indicate: Paper Jam, Clear Jam and Press OK, but there was no paper in the path at all. Found in HP forums that possibly the problem was a broken off piece that may be called the "x-bias" lever which is on a little spring inside the printer just to the left of the carriage bay on the right side of the device. There are two photos of "broken" and "not broken" at this forum site:
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1085918
Since HP does not sell the little part to repair it, I phoned HP and got a good "trade-in, trade-up" price for a better device. Hope this helps someone else find the answer to the constant paper jam issue, as I always appreciate the FixYa forum help from everyone else here, too.
Apr 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
162 people viewed this question
Ben Johnson
