Remove the left. panel on the machine. there is a screw in front and back. Once off near the front there is the mechanism that the front door actuates when closing. Near that there is a lever that sticks out into the area inside where the cartridge goes into the machine. This also can be see looking into the front of the machine on the left side the is a small black actuator that should move freely. It is jammed and popped out. Pop it back into place by pushing it back in gently from the side. This will fix your issue. Reassemble :)
the paper feeder jams every time a paper is fed through....it appears that some gum was on a piece...
(More)
the paper feeder jams every time a paper is fed through....it appears that some gum was on a piece of paper that went through the feeder...tried to clean it out, but it still jamming. How can we take apart the paper feeder drum?
Fax is plugged in properly...when it tries to send, it acts like it's dialing, but it never...
(More)
Fax is plugged in properly...when it tries to send, it acts like it's dialing, but it never connects...no matter what fax # I'm sending to. I have powered off the MFC, and I have also unplugged and plugged back in the phone cord both on the wall outlet and on the MFC.
