Question about Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television
9" VE927 LCD Drop Down TV
The sound works, but when I switch to TV, no picture
  • hyranch Mar 13, 2009
    would be interested in your player for parts.
3 Suggested Answers
  • 200 Answers
SOURCE: no picture 9" VE927 LCD Drop Down TV
are you sure the fuse is ok?
please see the fuse and check it
then use a different power socket
Posted on Oct 06, 2008
swami nathan
  • 208 Answers
I went through the manual.........
Take pg no: 30 of this manual www.retrevo.com/support/Audiovox-VE927-TVs-manual/id/3068dj099/t/2/
In this manual it is given if there is no picture : The region number of the disc doesn't match the region number of this unit.
Please read this manual and i hope it will solve your problem......
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
No picture 9" VE927 LCD Drop Down TV
Oct 06, 2008 | Audiovox VE927 9 in. Portable TV
The sound turn on but there is no picture
Most of the time you can unplug wait a few then replug and turn it back on and the picture will come back on.
Sep 08, 2013 | Audiovox VE927 9 in. Portable TV
Lcd no sound/picture when turned on
It sounds that the digital video processor section circuit has the fault. You haven't provided more details about your TV; brand name, model number etc; so it is not possible to post a solution to this problem. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there. Visit the site, and check whether it can help you.
Nov 26, 2012 | Televison & Video
When I turn on tv the picture comes on for about a second then goes dark. Sound works perfectly. Same thing occurs with every other channel. Same thing happens in dvd mode., sound but no picture. I have...
Sounds like it could be a bad inverter for the screen lamp. If it is a bad inverter and the tv is still under warranty you should send it back for a replacement or repair. If the tv is not under warranty and you have some experience working on electronic devices you could probably find a replacement inverter online and replace the bad one.
May 20, 2010 | Audiovox VE927 9 in. Portable TV
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Jun 08, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Repairing lcd tv.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Feb 17, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television Logo
35 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
