Question about Dell TrueMobile 2300 Wireless Router (tm23003)
Network key for truemobile 2300
How can I access the network for my truemobile 2300, thx for any help
Need more information for your problem.
Posted on Nov 02, 2008
NEED HELP TO SETUP MY TRUEMOBILE 2300 ROUTER TO MY DELL LATITUDE D600 LAPTOP. I HAVE BEEN TRYING TO GET WIRELESS CONNECTION. WHAT I DO HAVE , 1300 TRUEMOBILE PC CARD PLUG IN. WHAT I DON'T HAVE IS A...
The Network Key you're probably asking for is on a sticker located, underneath the router. Can you check?
Here's a way to configure your router for your existing network (assuming you already have one) :
If you have an existing network, chances are you have already configured network services on the network. In this case, you would use the router as a pure Access Point to extend the range of your network by allowing more attachment of wireless and wired computers. You MUST also turn off the DHCP server on the router if there is a DHCP server running to avoid IP address conflict.
To configure the router as an Access Point with the DHCP server disabled:
  1. Open your web browser and go to http://my.router, (or the default address http://192.168.2.1.)
  2. Click the Basic Settings tab on the top navigation bar.
  3. Select Access Point Mode.
  4. Click the Next button.
  5. Click OK to dismiss the DHCP disabled message box (The DHCP server will be disabled in Access Point Mode by default).
  6. Click the Advanced Settings tab on the top navigation bar.
  7. Click the Advanced IP Settings tab on the left navigation bar.
  8. Assign an IP address to the Wireless Broadband Router.
    note.gif NOTE: The IP address should be reserved by the DHCP server. The Wireless Broadband Router cannot act as a DHCP client, therefore, it needs a static IP address for its LAN interface.
  9. Click the Submit button.
  10. Click the Save & Restart button.
  11. Note the status bar at the bottom of the screen.
  12. While the Wireless Broadband Router resets, the Power light on the front of the unit blinks.
  13. When your web browser returns to the main page of the Wireless Broadband Route, the device has successfully restarted with the new settings.
    note.gif NOTE: The main page may not return if you have changed IP address of the router in Step 8. To view the main page, type the new IP address of the router in the web browser to access it.
  14. Plug an Ethernet cable from the existing local network into any LAN port on the Wireless Broadband Router.
Jul 01, 2011 | Dell TrueMobile 2300 Wireless Router...
I entered a WEP encryption key onto my Dell TrueMobile 2300 router, but when I try to connect to it wirelessly (and put in the correct key), I don't get any connection to the internet. It works fine when...
Dear Friend,
You must be trying the WEP -OPEN.
try WPA-PSK and put in your customized password.
Before making any changes in the system remove all the cables from the router and reset the router once and try to configure the network with WPA- PSK.
It should work.
If negative plz contact your ISP
Thank You
Prasanth83
May 11, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Cannot get truemobile 2300 to communicate with linksys usb network adapter Wireless light does not show in truemobile 2300 and link light does not light up on network adapter
To isolate the problem try installing the adapter to a different computer and if it works there it could be that your card slot is defective. As for the router try to reset it
Mar 06, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I HAVE AN OLDER TRUEMOBIL 2300 WIRELESS ROUTER WERE ARE THE KEY CODES TO MAKE IT SECURE OR DO I ENTER MY OWN AT RANDOM?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 22, 2009 | Dell TrueMobile 2300 Wireless Broadband...
I lost my wep key
what you can do i log into you router with the admin user go to wireless access settings and you would be able to see your WEP key, or if you want you can change it...!!
Jan 28, 2009 | Dell TrueMobile 2300 Wireless Router...
How do I set up a password to secure my wireless network??
Enabling the WEP for the Dell TrueMobile 2300 Wireless Router
Click the Start button.
Click All Programs.
Click Internet Explorer.
The Internet Explorer browser window appears.
Type the following in the Address line:
192.168.2.1
Click the Go button.
You are prompted for a Username and Password.
Type the following as your username:
admin
Type the following as your password:
admin
NOTE: If you previously changed your administrator password in the advanced settings of the router you will need type the password that you set.
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Basic Settings tab.
Click the Wireless Security button on the left side of the page.
The Wireless Security window will appear.
For the highest level of security choose the 128 Bit encryption option.
You will have to type a name for your encryption key in the field to the left of the 128 Bit option.
Click the Save and Restart button on the left hand side of the page.
The Save and Restart window appears.
Click the Save and Restart button.
Your settings will be saved to the router.
More Secure
Configure the 2300 Wireless Router for WPA-PSK with TKIP Encryption.
Double-click on Internet Explorer.
The Internet Explorer window appears.
In the Address Bar type my.router or the default IP address 192.168.2.1.
Press the <Enter> key or click Go.
The TrueMobile 2300 password window appears.
Type the User Name and Password.
NOTE: The default user name is admin and the default password is admin.
Click OK.
The TrueMobile 2300 Wireless Router configuration window appears.
Click Basic Settings.
Click Wireless Security in the left-hand pane.
Click to select Enable Wireless Security.
Under Network Authentication, select WPA (Wireless Protected Access) from the drop-down menu.
Input a network key or password in the field to the right of WPA Pre-Shared Key.
NOTE: Your network key or password can use 8 to 64 characters using Hexadecimal digits or 8 to 63 characters using ASCII characters.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Truemobile 2300 wireless router
tm1972:
Please consult the manual to reset the router to factory defaults this will give you full access to the router and this way you can reset PPPoE, check this out:
http://www1.ca.dell.com/content/topics/reftopic.aspx/gen/en/truemobile?c=ca&cs=cadhs1&l=en&s=dhs&~tab=3
Hope that helped!
Dec 10, 2007 | Dell TrueMobile 2300 Wireless Router...
If you are able can you reset the router in any way normally little reset button on back, or get into the routers set up page and try a restart.
Oct 29, 2006 | Dell TrueMobile 2300 Wireless Router...
Dell TrueMobile 2300 Wireless Router (tm23003) Logo
103 people viewed this question
Alun Cox
