Question about Whirlpool GGQ8831L Gas Dryer
Cannot remove blower from motor shaft
Cannot remove blower (plastic part shown as part 10 in illustration sheet)
from blower motor. I think it's just screws on, but will not come loose.
model wgd5500sq0 whirlpool gas dryer
can"t find model in selection below.
    Novelist:
    Champion:
  • 261 Answers
It does unscrew although at times they do stick. I would find a flat spot on the motor shaft and get a crescent wrench on it and lodge it so it doesn't move and then grasp the blower wheel and turn to remove.
Posted on Oct 17, 2008
2000 Eldorado blower not working
INFORMATION
Subject:
Revised HVAC Blower Motor Installation Procedures
Models:
1994-1997 Cadillac Seville
1994-1999 Cadillac DeVille
1994-2002 Cadillac Eldorado
The intent of this bulletin is to provide technicians information regarding the proper installation of the Heating, Ventilation and Air Conditioning (HVAC) Module blower motor (with impeller) assembly.
The current available HVAC Module blower motor for the above listed vehicles can be identified by the three mounting holes (1). The original equipment blower motor had five mounting holes.
In order to avoid confusion and ensure a high level of customer satisfaction, when replacing an HVAC Module blower motor, refer to this bulletin for the appropriate procedure.
Eldorado/Seville-HVAC Blower Motor
Caution: Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Removal Procedure
1. Disconnect the negative battery cable.
2. Remove the camshaft cover.
3. Remove the blower motor.
^ Disconnect connector from the blower motor.
^ Remove the blower motor screws (either 3 or 5 screws).
^ Remove the blower motor from the HVAC Module.
1. If present, remove the 2 ribs located on the barrier. Refer to Step 3 and the illustrations in the Instruction Sheet, P/N 52494110, found in the blower motor kit.
Important: Ensure the blower motor gasket makes a complete seal around the blower motor.
2. Install the new blower motor with heat shield. Refer to Steps 4 and 5 in the Instruction Sheet, P/N 52494110, found in the blower motor kit.
3. Install the blower motor retaining screws.
Tighten
Tighten the screws to 4 N.m (35 lb in).
4. Tighten the lower heat shield retaining screws to 4 N.m (35 lb in).
5. Connect the connector to the blower motor.
6. Install the camshaft cover.
7. Connect the negative battery cable.
Oct 09, 2012 | 2000 Cadillac Eldorado
How do I replace blower motor on 1997 Bravada
GM S-Series Pick-ups and SUV's 1994-1999 Repair Guide
Blower Motor - REMOVAL & INSTALLATION
Pick-Up models
Fig. 1: Blower motor assembly and resistor locations
  2. If equipped, remove the Vehicle Control Module (VCM) from the engine compartment.
  3. Remove the coolant recovery reservoir.
  4. Disconnect the blower motor cooling tube.
  5. Unplug the electrical connector(s) from the blower motor, as necessary.
  6. Remove the blower motor-to-case screws, then carefully withdraw the blower motor from the case.
To install:
  1. Install the blower motor to the case and secure using the retaining screws.
  2. Engage the electrical connector(s) to the motor, as necessary.
  3. If moved on early model vehicles, reposition and secure the A/C vacuum tank.
  4. Connect the blower motor cooling tube.
  5. Install the coolant recovery reservoir, then if equipped, install the VCM.
  6. Connect the negative battery cable.
Utility Models
See Figure 6
  6. Remove the blower motor-to-case screws (the lower screw is on the bottom front of the cover).
  7. Disconnect the harness from the blower motor.
  8. Use a razor or utility knife to cut through the cover on the cut line as neatly as possible because the access cover has to be reinstalled.
  9. Starting with upper half of the cover, tear the remaining part of the access cover from the remaining portion. Then remove the lower half of the cover in the same manner.
  10. Remove the blower motor assembly.
To install:
  1. Install the blower motor assembly.
  2. Connect the two halves of the access cover together using the three flange clips.
  3. Using black duct tape, place a piece of the tape along the bottom lower edge of the lower half of the lower cover only. The tape has to be the full width of the cover.
  4. Install the access cover onto the case.
  5. Install the screw and align the cut areas.
  6. Seal the cut areas using black weaterstrip adhesive. Do not use RTV to seal the assembly. The weatherstrip adhesive bead should be as straight as possible to ensure a neat and professional finish to the cover. Allow the adhesive to set at least 15 minutes until it skins over.
  7. Attach the electrical connections.
  8. Attach the cooling tube and install the coolant recovery reservoir.
  9. If removed, install the VCM.
  10. Connect the negative battery cable and refill the coolant reservoir to the proper level.
Fig. 2: Cut the blower motor access along the dotted line shown in this illustration
Hope this help (remember rated this help) Good luck.
May 13, 2010 | 2000 Chevrolet Blazer
I have to change the heater blower moter switch how do I do that
SECTION 412-02: Heating and Ventilation 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 10/6/2003 Blower Motor Removal
All vehicles
  1. Remove the footwell lower trim panel.
  1. Open the glove compartment.
  1. Remove the footwell vent air duct.
    • Pull off the hose.
  1. Close the glove compartment.
Vehicles with electronic automatic temperature control (EATC) built 11/2003 onwards
  1. Disconnect the blower motor control module electrical connector.
All vehicles
  1. Disconnect the blower motor electrical connector.
  1. Remove the blower motor.
Installation
NOTE: Procedure if there is a concern over whistling noises from the heating system.
  1. NOTE: Set the air distribution switch to ""Head area” and the temperature control switch to ""MAX cooling”.
    Remove the ventilation center nozzle and open the glove compartment.
  1. Unclip the passenger side defrost nozzle air duct and position it on the open glove compartment cover.
  1. NOTE: Do not allow any parts of the joining tang to pass behind the instrument panel.
    Remove the two-part plastic joining tang on the heater housing.
    • Cut the joining tang at the top end using side cutters, break it off at the bottom and discard it.
  1. Cut the sealing tape into a 50x50 mm square.
  1. ani_caut.gif WARNING: Sharp edges on the heater housing.
    Feel for the gap in the heater housing, affix the sealing tape over the gap from the inside and press it firmly in place.
    1. NOTE: Apply the sealing tape in the position shown. The sealing tape must not be applied higher than the position shown in the illustration.
      Heater housing (shown in cross section)
    1. Sealing tape
  1. To install, reverse the removal procedure.
2010&c18=modelyear&c20=g18286&c35=wsm%2cblower%20motor%2csyy%2c412-02%2cremoval%20and%20installation&pid=wsm%2cclimate%20control%20system%2csyy%2c412-00%2cdescription%20and%20operation&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=29&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=491&ct=lan&hp=n&[aqe]
Apr 04, 2010 | 2000 Ford Focus
2005 malibu - heat/ac has 4 levels for fsn, level
Your blower speed resistor has gone bad and needs to be replaced. You can pick one up at Auto Zone or Parts Source with the step by step instructions to getting the resistor replaced with common tools.
It is located under the glove box, way in the back of the passenger foot area. You'll need to remove 2 screws with a 7mm socket, and remove the plastic cover that covers the blower motor and another component box that I think controls the passenger airbag. After removing the plastic cover you'll need to side that passenger airbag module to the right so it pop off its mounting bracket and move it out of the way. That will give a better view of the blower motor. I highly recommend you also remove the blower motor itself because the Blower Motor Resistor is located behind it. I think you'll need a 5mm or 5.5mm socket to remove the 3 screws that hold in place the blower motor and 2 more screws for the Blower Motor Resistor... It's a cramped location to work in but if you have all the tools and enough lighting then it shouldn't take more than 30-60 minutes to do. The Blower Motor Resistor costs about $19-$25. Good luck
Nov 30, 2009 | 2005 Chevrolet Malibu
My fan only blows in the 4 and 5 speed mode
Auto Zone sell the blower motor resistor pack for the manually controlled fan speed for $28 (they may also have the automatic or climate control types, too). I did this job myself in less than 30 minutes with a flashlight and simple hand tools. You might have to get into a slightly awkward position to see & remove / reinstall the screws that hold the resistor pack in place under the dashboard.
1) Remove the two screws from the plastic cover under the glove box & disconnect / remove electrical connectors secured to the cover. Set the cover aside.
2) Empty the glove box of the contents.
3) With the glove box open, push the clip on rear of the left side of the glove box towards the firewall to allow it to fall forward.
4) Remove the electrical connector from the blower motor located to the right of the glove box opening.
5) Pull the connector and cable downward tot he floor. There is a thick rubber band that may be holding the cable - pull it away to slide the cable out easily.
6) Close the glove box.
7) Look upward - close to the firewall to follow the cable removed in a previous step (a flashlight can help out here). It enters a plastic part held in place with two screws. There is also a narrow electrical connector on this plastic part.
8) Disconnect the narrow electric connector by pulling it straight downward.
9) Remove the two screws that hold the plastic part in place.
10) Allow the part to fall / gently pry away from surface.
11) Reinstall in reverse order.
The part is Duralast #DR755 shown below:
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?categoryDisplayName=Climate+Control&fromType=parts&fromString=search&parentId=52-0&currentPage=1&filterByKeyWord=blower+motor+resitior&isSearchByPartNumber=false&navValue=15201160&categoryNValue=15299999&fromWhere=&itemId=1160-0&displayName=Blower+Motor+Resistor&searchText=blower+motor+resitior
I hope this helps!
Oct 29, 2009 | 2004 GMC Envoy
BLOWER FAN MOTOR DOES NOT WORK IN LOW SPEED
This is usually caused by a failing fan motor resistor. The resistors allow changes the speed of the fan. If one or more fail, certain speeds become unavailable.
Auto Zone sell the blower motor resistor pack for the manually controlled fan speed for $28 (they may also have the automatic or climate control types, too). I did this job myself in less than 30 minutes with a flashlight and a few simple hand tools. You might have to get into a slightly awkward position to see & remove / reinstall the screws that hold the resistor pack in place under the dashboard however.
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?categoryDisplayName=Climate+Control&fromType=parts&fromString=search&parentId=52-0&currentPage=1&filterByKeyWord=dr755&isSearchByPartNumber=true&navValue=15201160&categoryNValue=15299999&fromWhere=&itemId=1160-0&displayName=Blower+Motor+Resistor&searchText=dr755
I hope this helps!
Oct 26, 2009 | 2004 GMC Envoy
How to replace a blower moter resistor on a 2004 envoy
I hope this helps!
Oct 22, 2009 | 2004 GMC Envoy
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
How do i pull out a faulty heater blower motor from behind glovebox in 91 accord?
For Pictured Detailed Innstruction see Bottom of Page
BLOWER UNIT REMOVAL
  1. Remove the glove box.
2. Remove Glove box FRAME
3. Pull back the carpet and remove the kick panel. Remove the control unit bracket mounting nuts (4). Disconnect the connectors (5) and remove the control unit and bracket.
  1. Without A/C:
    • Remove the self-tapping screws (3) and remove the heater duct.
    • Remove the blower (3 nuts).
  • If the car has A/C, remove the blower unit according to the sequence shown
  • BLOWER MOTOR REPLACEMENT
    Refer to illustration for blower unit disassembly and reassembly, noting the following:
    • Before reassembly, make sure that the air door and linkage moves smoothly without binding.
    • When reattaching the recirculation control motor, make sure its positioning will not allow the air door to be pulled too far. Attach the recirculation control motor and all linkage, then apply battery voltage and watch the recirculation control door movement. If necessary, loosen the holding screw and move the recirculation control motor up or down
    • CONTROL ROD ADJUSTMENT
      Connect the recirculation control motor connector to the main wire harness and turn the FRE/REC switch to "REC". Hold the air door closed, then connect the control rod to the clip on the arm.
    • Email Me at the nickkname shown here >>rejakwilson @aol.com
Jan 18, 2009 | 1991 Honda Accord
2001 dodge grand caravan blower motor not working
OK So, I have had to replace the blower resistor twice and its still has failed. Now its time to replace the blower motor. I have the Haynes manual for this vehicle but it seems to miss some important steps. Here's what I did, I hope it helps you. This job is given 3.5 hours on the shop book and believe me, its not a wonder why.
Tools that I used
- standard screwdrivers 6" with 1/4 blade and 8" with 1/2" blade
- 1/4 inch ratchet with 2" and 1" extensions
- 8mm socket
- 10 mm wrench
- Phillips S2
- drill with attachment for screwdrivers ( I have tendonitis)
- gooseneck extension (plastic / flexible)
Here are the instructions from the Haynes book with my comments and pictures.
One note is that the picture in section 3-8, fig 10-10 is upside down. The Actuator motor is on the bottom of the unit, looks
like a black deck of cards with a wire going to it. Wires at clipped to the housing.
2001 and later models
Step 8 - Disconnect battery negative cable - Wrench 10mm (1/2inch)
Step 9 - Partially remove instrument panel.... - remove glove compartment to access the blower and evap area. Two clips on
either side, unsnap hinges. ( remember to empty the box)
Step 10 - Disconnect pigtail from blower motor resistor. Green/Black wires
Step 11 - Remove 2 screws to remove actuator. (8mm socket) Remove wire from clips and pull down to remove the acuator. This
will buy you about 1/2 of extra space. Before you do all this, remove the side carpet trim which allows you to pull back the
carpet and the silencer padding. This will allow for some more room to pull the housing down and believe me, you'll need it!
Step 12 - Remove 2 more screws on the air intake and lower housing. I had three screws, you should see them through the
glove box.
Step 13 - Remove the 3 screws at the lower intake and lower evap housing.
Step 14 - Push rubber grommet through hole in lower housing. Use large blade screwdriver.
Step 15 - Remove lower intake housing from evap housing.
This is where it gets tricky.
You can remove the lower intake housing but you need to pry it out from the recirculation door.
The bottom of the unit where the actuator was has a round spindle that clips into place with the three plastic clips.
Lightly pry the lower clips and then also pry through the hole at the connection point. Picture below.
Once you pry it will release.
You will have to jiggle this loose but it will eventually come off.
with mine the recirc door POPPED out of its top rest. I had to make sure on how to get it into this spot as it doesn't stay in this spot.
Step 16 - Push wires through the hole if you haven't done so already.
Step 17 - Move recirc door about to help you reach the three screws that hold down the motor assembly.
Step 18 - GENTLY flex the door to remove the blower motor and wheel. I moved the motor 180 to help get into a better position.
Install is reverse. Need to make sure that the recirc door moves relatively easily. The calibration below will make sure all is set properly. If it doesnt pass you'll have to recheck the position of the recirc door top spindle and cavity line up.
Step 19 - Not in the book
18. Perform the heater-NC control calibration procedure:
a. Turn the ignition switch to the ON position.
b. Simultaneously depress and hold the Power and Recirculation buttons on the heater-A/C control for at least five seconds.
The manual heater-A/C control Delay Light Emitting Diode (LED) and Recirculation LED, or the Automatic Temperature Control
(ATC) heater-A/C control Delay and Recirculation graphics will begin to flash when the calibration procedure has begun.
c. The calibration procedure should take less than three minutes to complete for the manual system, and less than twenty
seconds for the ATC system. When the LED's or graphics stop flashing, the calibration procedure is complete.
d. If the LED's or graphics continue to flash beyond the time stated above, it indicates that the heater-A/C control system
has detected a failure and a Diagnostic Trouble Code (DTC) has been set. Use the DRBIII(R) scan tool and the appropriate
diagnostic information for further diagnosis.
Jan 16, 2009 | 2001 Dodge Grand Caravan
Whirlpool GGQ8831L Gas Dryer Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
