Question about Yamaha Audio Players & Recorders
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
I have a Yamaha RX 596 receiver and the Yamaha RAX7 VZ45350 remote controller that came with it. I can turn the receiver on using the remote, but not off. To turn it on I use the "standby/on" button. There is a "sleep" button, but no "off" button. What do I press to shut off the reviver using the remote?
Thank you,
  • Yamaha Master
  • 5,306 Answers
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: . The page is also available here: .
I hope this helps.
Posted on Jun 28, 2017
5 Suggested Answers
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
SOURCE: Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
  • 8546 Answers
SOURCE: Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Posted on Feb 13, 2010
Yamaha rx-n600 what universal remote will work this reciever
Hi U can buy Yamaha Remote's on E/BAY TO SUIT you're RX-N,600. US $46.99 ,good luck
Dec 15, 2016 | Yamaha RX-N600 Receiver
No volume
You need to check the settings and also check the connection from receiver to five speakers .
Oct 28, 2008 | Yamaha AX-596 Amplifier
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
How to troubleshoot remote controll
Most Yamaha receivers have a remote ID so if you have more than one Yamaha you can control one without bothering the other, do you still have your owners manual? If not have you tried the people at Yamaha they are very helpful with a problem like this but for an example I have my Remote ID set at ID1 because I do have 2 Yamaha receivers the RX-V1300 and the RX-A3020, see if you can find the section in your manual that talks about remote IDs and let me know if that fixes the problem and you can always goto but that is the site for the United States they do have sites for many countries at
Apr 26, 2014 | Yamaha RX-V659 Receiver
Hi, I have a Yamaha RX-V596 that all of a sudden developed a hum throughout ALL speakers, it is coming from the receiver. Any idea how to fix it? Thanks, Adam
reconnect all wires (make sure are placed in correctly) and make your connection with wires kind of tight (no druppy wires if extra coil it up) between devices....your receiver should have small wire hanging this is the antenna and the other wire should be grounded...and should take care of the humm....
feel free to rate the help
Jun 12, 2010 | Yamaha RX-596 Receiver
Can I adjust the level of each channel from the receiver, not from the remote control (the level button on mine is not working)?
Depends on the reciever, some due and don't, my advice is to get a universal remote that will work with your reciever and then you can adjust your settings no problem. I own a Yamaha RX-V3800n and you can hardly do anything without the remote.
Hope this helps
Sep 24, 2009 | Panasonic SA-HE7 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
Feb 04, 2008 | Yamaha RX-V800 Receiver
Hooking up this receiver
I don't see why not. I have a 46" Sony Bravia HDTV that I have hooked up to my RX-V596.
Just use either the RCA out on your TV to the "TV " RCA audio in on the receiver, or if your TV has Optical or Coaxial Audio Out use those...
Dec 27, 2007 | Yamaha RX-V596 Receiver
63 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
