No internet connection even though toolbar icons arew saying internet connection OK and wireless network OK.
  • 52 Answers
Try to contact your ISP, the problem might be in their network.
Posted on Oct 17, 2008
No wireless connection suddenly. internet only works by cable in laptop and home hub
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Jan 15, 2013 | Toshiba Satellite Computers & Internet
No wireless download
Jan 15, 2013 | Computers & Internet
My wireless network connections r missing
click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Dec 17, 2012 | LG X-Note LM50 Notebook
How to switch on wireless
Dec 10, 2012 | Computers & Internet
How i do keep my wireless switched on
hope this helps
Sep 26, 2012 | Computers & Internet
No internet connection via router
1. check your firewall settings.
2. Go to the router and check the status by entering into a browser page 192.168.0.1 or 192.168..1.1 this will bring you to the routers setup page and active icons. choose the status.
3. You can unplug the router reboot the PC for one minute and try connectivity again.
4. check the ISP to check you connection even though you say that it is OK.
Apr 23, 2010 | Dell Wireless 2350 Router
I cannot get my laptop to connect to the internet either wirelessly or hard-wired. I have two other laptops, connected wirelessly, and a desktop connected via hardwire. It recognizes the router but says...
if you are trying through wireless, first unplug the wire from the laptop,
make sure that the wireless switch on your laptop is turned on.
click on start, control panel, network connections/network & internet/ Network and sharing center..
right click on wireless network connection Icon, if it says disable, it means it is enabled already.
then click on status..
from here the steps would differ from OS to OS
then click on Support tab (for XP)
check the address type, it should be "Assigned by DHCP"
and if you see the IP Address starts with 169., it is a bad IP and needs to disable the connection and enable it.
if the connection type is "Assigned Manually, right click on wireless network connection icon and click on properties and click Internet Protocol(TCP/IP) and click on properties, in this window, check the option "Obtain IP Address Automatically from DHCP"
click ok and OK ..
again right click on the wireless network connection icon and click on view available networks... click on your router name and click on connect..
now check the functionality.
if you are using windows 7 or vista,
click on status, click on details for the IP Address..
We see DHCP Enabled as YES or NO instead of "Adress type"in XP
if it says no, it means it is assigned manually. to change to DHCP , right click on Wireless Icon, select properties, click on IPV4 IP address and click properties, then select obtain automatic..
then try again..
hope this works,
Narendra Tirunahari
Feb 18, 2010 | Gateway 7330GZ Notebook
Acer extensa 4620 Since purchased, wirelss
Try turning off your Acer wireless control and use "Wireless Zero Configuration"
Nov 27, 2009 | Acer Extensa 4620 Notebook
My netgear isent working even though it says it has a signal
Follow the steps below to configure wireless connection:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 03, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Excellent connection wireless but not connected to internet
goto start icon in your toolbar.
goto run
type: cmd (press enter)
(a black box will come up)
type:
ipconfig /release (press enter)
ipconfig /renew (press enter)
if this does not work, goto start, control panel, view classic settings, click network, you should see you network connect as an icon here, right click the mouse over the icon, select repair. the computer will do a variety of things.
sometimes hotels have a login page that you have to log in through as a guest with your room number to get them working. or, the router might be set to MAC filtering, in which case you need to give the admin you MAC address so you can get on the network.
double check that you are actually getting on the right network. sometimes people set up dummy networks to capture all your data.
Jun 25, 2009 | Dell (04U621) for Latitude D600, Inspiron...
Computers & Internet Logo
David Payne
David Payne
