Question about Hotpoint Dryers
How can I get into my hotpoint CDT00 dryer.
I need to get into the dryer to change the fan but cant get the back or sides off. can you help.
  • jodiem1 Oct 17, 2008
    many thanks thats done the trick !!!
  • 67 Answers
Most dryers come apart from the front. there is usually 2 screws holding the bottom panel on the front. once that is removed, there is usually 4 screws holding the front panel on. when both of those panels are off, you can pretty much get to anything you need to.
Posted on Oct 17, 2008
Hotpoint Aquarius CDT00 reverse action tumble dryer. Spins but no heat. Empted water and cleaned filter.
I have exactly the same problem, I am searching desperately for a solution. I really dont wont to buy a new one!
Jan 05, 2011 | Hotpoint Dryers
My hotpoint cdt00 tumble dryer makes a loud banging noise on each rotation what is causing this
It is probably a worn rear drum bearing, remove cover of drum shaft, and examine the drum shaft for wear.
Jan 17, 2010 | Hotpoint Dryers
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
CDT00 Hotpoint aquarius dryer The draw that contains the water is not filling up properly and instead waste water is flooding the floor........any ideas on how to cure this would be much...
pump at the back is most likely blocked or failing ... there are hoses running down the back make sure these are clear as a fisrt port of call .. also remove heat exchanger and make sure there is no build up of wet damp fluff blocking anything .. always remove from mains before attempting any repair
Apr 13, 2009 | Hotpoint NWXR473EV Dryer
Dryer CDT00 not getting any heat.
Suggest you check the heater and thermostat(s), to be found at the rear of the m/c behind a removable panel., you will need a meter to do this.
If o/k then problem could be faulty control or relay if it has one..
To be found at the top front.
Nov 16, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint condenser dryer CDT00
how to connect the dryer belt to the motor is there is two pullys.
Mar 30, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Jan 19, 2008 | Dryers
Dryers Logo
111 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
