Question about CTL Nexus NX3200 Television
Set will shut down after 5 seconds
When turning the set on either manually or with a remote control, the set will shut down after 5 to 10 secords.
  • 14 Answers
That normally indicates that your control board is overheating.  You can call Nexus Support at 800-642-3087 ext 235 and they can take care of getting you a new one.
Posted on Mar 30, 2009
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
I lost the manual I need instructions to program it
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thank You
Sep 12, 2010 | Hitachi VT-RM294A Remote Control
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
Hi.
Manual Programming:
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Need instructions on how to program a RCA model RCR 3273N universal remote
Hi! There are two ways on how to program your RCA Universal Remote Control. First is the direct code entry. In following these steps you need to provide me the type and brand of the device you want to be programmed to your remote control so I can give you the code for that certain device. Since you did not indicate the information I need for the code I will advise you to do the second way which is the Auto Code Search. Here are the steps for you to be able to program your Universal Remote without the code list.
1. Manually turn on the device you want to control.
2. Press and hold the device key you want to program. While you’re holding down the device key, use your other hand to press and hold the remote’s POWER key at the same time.
3. Wait until the remote’s indicator comes on and stays on. Then release both keys.
4. Point the remote directly at the front panel of the device you want to control. Press PLAY on the remote and wait 5 seconds. The remote is testing a batch of 10 codes on your device.
Did your device turn off?
YES: Go to step 5.
NO: Press PLAY again. The remote tests the next batch of 10 codes.
Keep pressing PLAY every 5 seconds until your device turns off.
5. When your device turns off, press the REVERSE key on the remote
and wait at least 2 seconds. The remote tries the last of the previous ten codes.
Did your device turn on?
YES: Press the STOP key. You’re done! You’ve programmed this device key.
NO: Press REVERSE again. The remote tests the next code in the batch. Keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
Note: If you accidentally press the REVERSE key after your device turns on, press the FORWARD key. Then, wait two seconds to see if your device turns off again.
Jun 14, 2010 | RCA Universal Remote Control
Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
I HAVE DVR RECORDER
i had the same problem. press enter, hold it down and press and hold 1 for about 10 seconds.
Jan 18, 2008 | Panasonic DMRES15 DVD Recorder
CTL Nexus NX3200 Television Logo
136 people viewed this question
Top CTL Televison & Video Experts
Are you a CTL Televison and Video Expert? Answer questions, earn points and help others
