Question about Compaq Presario 5000 PC Desktop
I want Upgrade my computer memory
I have compaq presario 6000 P4 .
I want upgrade memory . Now before buy a memory ,maximum how much memory i can add & what things i suppose to chek like PC2100.PC2700 ,PC3200 & 133 MHZ ,266MHZ , DDR,DIMM .Lots of thing to check .
Can you tell me please.
Thanks
ZAKIR
    Sergeant:
    New Friend:
  • Compaq Expert
  • 124 Answers
Add DDR PC 2700. You can easily buy RAM on low price.
2 GB DDR2
Posted on Mar 06, 2015
    Scholar:
  • 94 Answers
You need DDR PC 2700 184pin memory. Your machine will support upto 2g.
You can buy this memory from anywhere at cheap prices.
Hope this helps
Regards
Posted on Oct 16, 2008
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
I own a compaq presario 6450nx and I would like to upgrade it. like adding more ram and replace the cpu if its posible, what could be the suggestion?
This is info on your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Your system comes with Intel P4 2.53 GHz processor and 512MB ram. total ram could be 1GB, bt adding another 512MD stick. You have Socket 478 and processor would be up to you. The system comes with a 200w power supply so, in an upgrade, you should up the power supply. You have an AGP expansoin slot and, you could upgrade to a graphics card but again, power supply is only 200w. The system as it stands is not Windows 7 compatible. If you incraesed your ram and got a graphics card, you would get better performance.
Jun 13, 2011 | Compaq Presario 6450NX (DA238A#ABA-BDL1)...
I have a compaq Presario SR5050NX and wish to max RAM
Yes, you can only upgrade to the 2GB limit using DDR2 SDRAM
Here is a link for you.
Hope this helps.
http://reviews.cnet.com/desktops/hp-compaq-presario-sr5050nx/4507-3118_7-32399105.html
Nov 03, 2009 | Computers & Internet
Have a presario 700 and want to upgrade the ram. Where is it located and how much can I add. tried pushing F1 when starting to get the screen that tells you
  • Maximum Memory: 384MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 128MB non-removable
  • Open the bottom plate of the laptop and read the current information on the ram inside. this will tell you the type to buy....try http://www.pricewatch.com to buy it
    Oct 24, 2009 | Compaq Presario 700 470024-192 Notebook
    Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
    Thanks to Microsoft Knowledge Base for help with my answer:
    First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
    Jul 07, 2009 | HP Compaq Presario V3000T Notebook
    Memory upgrade
    First step : Make sure the memory you purchased meets the following specifications
    "168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
    If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
    Mar 14, 2009 | Compaq Presario 5000 PC Desktop
    Trying to price/find ram upgrade for compaq presario m2000
    You can go to the manufacturer website and check on the product model specifications to show you the correct limits. For example, if you have a hp laptop, go to www.hp.com and enter your product model in the search. then look for product specification page and you should be able to verify the memory limits
    Mar 10, 2009 | Computers & Internet
    NOTEBOOK CPU UPGRADE
    Good afternoon. Procedure of the change the processor can be very complex technically. It very simple to add some memory modules and increase productivity of yours notebook in this case.
    Mar 07, 2009 | HP Compaq Presario C304NR Notebook
    How much RAM does a Compaq Presario v2000 would allow?
    The Compaq Presario v2000 has a max ram capacity of 2.0gb.
    You would need to purchase 2x 1gb ram modules are there are only two bays for these to go into. You would need to purcahse PC2700 DDR SDRAM SODIMMs.
    Jan 12, 2009 | Compaq Presario Notebook
    Upgrade laptop
    Hi
    Only you can upgrade laptop ram and hdd. You cannot upgrade your graphic card, try to upgrade your ram it will improve speed....
    Apr 01, 2008 | HP Pavilion dv6000z Notebook
    Compaq Presario 5000 PC Desktop Logo
    149 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
