Question about Acer AL1916W 19" LCD Monitor
Monitor is connected to laptop jack and displays "no signal"
I have connected the monitor to the jack on the back of my Dell laptop. All lights on all devices are on. When I go to turn on my monitor screen, it displays "No Signal" and then the light on the monitor turns orange.
It DID work, on the laptop, for a couple of times when I first brought it home. It works perfectly on the PC at the office. However, we closed the business and I inherited the screen. I would like very much to use the larger screen, as the laptop screen, over time, hurts my eyes. Can you please help?
    Novelist:
  • 159 Answers
You have to activate the video out of the laptop.
Two ways to do this depending on how you want to use the monitor.
To use the monitor by itself laptops have shortcut keys.
Usually they involve using the Fn key and one of the F keys (Usually F3-F4-F5) KEy will either show two screens or say CRT-LCD
Pushing both keys at once will switch you to both screens, pushed again will just run the monito, Pushed again will return you to the laptop screen.
If you want to use the monitor as an extension of the monitor to be able to drag windos over to it then go to your display properties from the control panel and activate the monitor in the settings box. You'll have to click the monitor first then activate it as a extension and adjust the resolution here.
Fran
Posted on Oct 16, 2008
The laptop screen will not come on. it shows the dell powerup logo then goes black. The monitor lights are on so it is getting power but it isn't showing anything on the screen
If it's a Mini 1012 there is a VGA (15 pin) connector on the left side of the laptop. You can try to connect an external monitor to see if you get a display. If you do, then your LCD display has a problem and needs to be replaced. If you have a Mini 1010 there is an HDMI jack on the right side of the laptop where you can connect an external monitor.
Jan 26, 2011 | Dell Inspiron Mini 10 Notebook
When i connect my laptop to the tv i get sound but no pic.
Computers have two seperate systems - one for video and one for sound.
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two seperate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video+sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Feb 11, 2010 | Dell Studio 1537 Laptop
Cant connect to laptop (only shows desktop no playback)
if u r connecting a laptop to an external monitor...just connect the monitor cable to the monitor jack in the laptop and u need to make changes to the display in the control panel...
Control Panel/Display/Setting tab/Advanced/Monitor or Display Tab...there u will get the choice to send the signal to either the monitor or laptop display...
chose and freez the choice....
Dec 14, 2009 | NEC MultiSync FE700 17" CRT Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Getting audio from a Dell LCD Monitor when connected to a Laptop
connect the audio cable to laptop and LCD monitor...
.35mm male to male jack
connect the cable to your laptops headphone jack and the other end of cable to the monitor
the VGA and DVI cable are for video only
Apr 02, 2009 | Computers & Internet
Problems with external monitor
Typical issue is the second monitor resolution got set too high for the monitor to generate a picture. Go to display settings and adjust the resolution down to see if it comes back.
Mar 30, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
I cant get my acer aspire one to connect
your describe: connect a laptop VGA out to a monitor but no signal: you need check
1) newer monitor have two signal interface (analog or digital) and you may try to do a logical change the signal way by select buton
2) any laptop have two way display (local LCD or extenal VGA) change by the key (fn+f key showing creen icon)
Nov 08, 2008 | Dell E207WFP LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
