Question about Brother DCP 7010 Multifunction Laser Copier
Brother dcp7010 all my printed pages have 4 dots on right hand side how do i get rid
As above
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
If this 4 dots have equal positions from page 2 page: *replace OPC or replace drum unit
If this 4 dots have non-equal positions from page 2 page:
*do Preventive maintenance for your Brother
Posted on Oct 17, 2008
I have a Brother MFC 8460N that prints three black dots down the right side of each page when going through the printer. I have tried cleaning and it does not work. The black dots show up on copies as...
Measure the distance between the dots and that will give you the answer to which roller is causing the problem I believe the Drum is the only roller large enough to just cause three dots.
Aug 28, 2013 | Brother MFC-8460N All-In-One Printer
I am printing a brochure that i created on microsoft publisher, but i can't get it to print double sided the right side up for both pages
Hello:
The Brother DCP-7030 supports manual duplex only. When choosing duplex (2-sided) printing, it will print the even-numbered pages first and prompts you to reinsert the pages in a different orientation.
To correctly print the second side of your brochure, you could do one of two things:
  1. Reverse the orientation of the paper when you reinsert if for the second side of printing.
  2. Reverse the direction of the second page in Publisher.
The first option is simple enough. When the Brother driver directs you to insert the paper for the second side, insert it in a rotated position. It should be on the same side, but rotated 180 degrees.
The second option is also easy, but if you want to edit the document in the future, it will involve in some work before being able to edit it.
  1. In Publisher, select all of the objects on the page (pressing "Ctrl" and "A" on your keyboard at the same time will accomplish this).
  2. Right-click on an object on the page.
  3. Choose "Group"
  4. Your objects are now grouped into one item.
  5. There should be a green dot at the halfway point at the top of the group. You can click and drag this dot until the object is rotated 180 degrees. Alternatively, you could go to the menu and choose "Arrange>Rotate or Flip>Rotate Left 90 degrees" twice.
  6. Now when you print, you should follow the Brother driver directions when flipping the paper.
Jan 14, 2011 | Brother DCP-7030 Digital All-in-One Laser...
Blue dotted line of right side of paper
Sounds like the cyan photoconductor unit needs to be replaced. Usually what ever the color dot is that photoconductor has a pinhole in it and the only to get rid of it is to replace it.
Apr 06, 2010 | Ricoh Aficio SP C411DN Laser Printer
My printer consistently prints black dots/blots on the left-side of the page (2-3 per page). What can I do to get rid of these dots?
Make sure the printer cartridge is not punctured or damaged. You can check this by taking out the cartride and look for ink spilled on it.
Nov 15, 2009 | Brother HL-5240 Laser Printer
Three dots on right hand side
pls replace the toner because it is a toner problem.
Sep 17, 2009 | Brother HL 1440 Laser Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
How do I reset the drum life of a DCP7010
never ver use refil toner on brother products. to answere your first question 1 open the front cover 2 push menue button scroll down to machine info press set buton 3 scroll down to drun lif - push set
Jan 09, 2009 | Brother DCP 7010 Multifunction Laser...
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Brother DCP 7010 Multifunction Laser Copier Logo
239 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
