Question about Acer Aspire 3680 Laptop
Second monitor hi, thanx for the reply to my post. ive tried adding to it but cant seem to! so thought id try this instead. im trying to connect using svid cables to a tv. ive tried the fn and f5 keys but all that shows up is the laptop. any ideas?
    Genius:
  • Acer Master
  • 1,252 Answers
Check the cable on some different laptop
Posted on Oct 17, 2008
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
Hi i cant sign into yahoo messenger ive tried
u must b using wrong email id and password..check with othr id
Sep 13, 2009 | Yahoo Messenger
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Thanks for trying
I think you did right. Using MSI's web site. the nforce will list the latest drivers but re-call you checked them & their dates were the same as MSI's. It's better to wait untill you can connect with the nVIDIA site directly.
The error you received for the floppy. (this could be a linked issue for you're SMbus controller). Read the link profided.
http://www.computerhope.com/issues/ch000474.htm
Get that out of the way before the SMbus controller can be addressed.
Mike
Apr 07, 2008 | MSI K8N Neo3-F Motherboard
Im having a problem w/my wii
Is it not getting an IP from the Router? Try resetting the router and see what that does...
Mar 25, 2008 | NetGear WGR614 Wireless Router
MASSIVE problems, need urgent help!
To keep people updated. I have sent my AV500 to Archos Repair Dept. Their phone support seemed fine. Hopefully their turn around time will be as good too.
Oct 18, 2007 | Archos AV 500 Digital Media Player
Epson TM-U220D Printer Status
Hi, On the PC that will not display printer status correctly, pls run MSCONFIG (start, run, type "msconfig", OK); in the System Configuration Utility Window, click on the tab Startup, see if the EPSON Status Monitor is present and checked. If it is not present, check if you have Lavasoft Ad-Watch or similar program running. This prevents the EPSON Status Monitor from registering and running correctly. If such a program is running, temporarily remove Automatic setting and reinstall the EPSON Status Monitor. Accept any registry modification at this point. Restore all settings once installation is finished. If still a no go, try wiggling the parallel connector a bit and make sure it is snug and fit. If all else fails, you may have to consider: Installing to only 1 PC, share and make it a print server assuming you have networked all your PCs; or re-installing Windows (Ouch!) Hope things work out for you. Pls post again how things turn up. Kind regards.
Jul 30, 2007 | Epson TM-U220D Matrix Printer
Schematic for Zenith IQB50M90W, and a problem.....
A service manual is available from http://www.servicemanuals.net for a download for about 24 bucks. I have An IcQ50H94W. Your problem sounds like a bad solder connection or a regulation problem. Good Luck PS please dont forget to rate this thread.
Oct 30, 2006 | Zenith IQB50M90W 50" Rear Projection...
Acer Aspire 3680 Laptop Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
