Oritron DAV 3102 volume problems
I too have the same problem. How did you solve yours. Please let me know all possible solutions/suggestions you got.
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: lost manual
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
Posted on Jul 15, 2008
MANUEL INSTRUCTIONS POUR CINEMA MAISON ORITRON DAV 3102 EN FRANCAIS S.V.P.
If you wish to get some details; visit the site linked here.
Feb 09, 2017 | Oritron Televison & Video
Need manual how to hookup oritron dav 3102
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 11, 2011 | Oritron DAV3101 PROGRESSIVE SCAN DVD
Msg O4
Ask http://manualfox.com - they found the user manual for DAV 3101
Dec 30, 2008 | Oritron DAV3101 PROGRESSIVE SCAN DVD
Oritron DAV3102 No sound to speakers
I have the exact same problem. It stopped working a couple of days ago. Let me know if you find a solution.
Thanks, Nicco
suavenicco@gmail.com
Aug 23, 2008 | Oritron DAV3101 PROGRESSIVE SCAN DVD
Sony dav-x1
The simplest solution would be connect the headphone jack on the iPod to the stereo audio inputs (RCA) to your home theater. So you need a cable that is "stereo phono mini jack" on one end (into iPod headphone jack), and then Y-splits into two RCA connectors on the other end (into L and R audio in on the receiver).
The expensive Apple-endorsed Monster-branded version can be found at http://store.apple.com/us/product/TN983LL/A#overview for $30, but you can get the same thing at Radio Shack for $7.
http://www.radioshack.com/product/index.jsp?productId=2102974&cp=&sr=1&origkw=phono+jack+rca&kw=phono+jack+rca&parentPage=search
Set the iPod volume to less than ~80% and then control the volume using your receiver. You have to use the iPod menu to select music.
May 12, 2008 | Sony DAV-X1 System
Oritron DAV 3102 home theater system
I found a website for the remote you need. I need one too. Go to remotes.com and put your model number of DAV 3102 in the space. It will show you the original remote and a replacemet you can use. Kind of expensive but worth it to me.
May 04, 2008 | Oritron DAV3101 PROGRESSIVE SCAN DVD
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
Repapir Facility
I don't have a solution, but I hope you at least got a response from Fixya, because I have sent several requests about the same problem never got any response. Either they don't care or don't know. Hotch74@frontiernet.net
May 31, 2007 | Oritron HT240 System
DAV3102 not enough volume
I have a DAV 3101 and the sound level is much better if the optical input is used. If you use other then supplied speakers you can blow the unit up. It uses 50uF electrolytic capacitors inside the front speakers (3) TO SAVE SPACE IN THE MAIN BOX. However, my unit will shut itself off. Standby light flashes and won't turn on until line cord power is reset over nite. Too bad Oritron doesn't support their products. Their web site is poor. I couldn't find an authorized repair service. Buyer beware! Tom H
Oct 18, 2006 | Oritron DAV3101 PROGRESSIVE SCAN DVD
 Grubhead
Grubhead
