DIM SCREEN my laptop is coming on but i am not seeing anything on the screen. i can make out a fade out line in the back ground. I was told may be it is the LCD screen and inverter. what do u think? And how can i locate the part to order it? urgent I also have an Acer Extensa 4620-4605 laptop that will not light up.. I have tried 3 different inverters, two different lcd screens and a new cable. I even replaced the motherboard, but my LCD will not light up. I think the inverters I bought were not good or the wrong ones. I have also checked lid switch. Any Ideals or where can a person buy a new 4620-4605 inverter. Certainly not at ACER.com. I can't find anything there. HELP HELP HELP
  • jbdeckert247 Oct 17, 2008
    All you did was repeat what I told you! Anyone out with real solution and not Mr. Ovioius type comment?
    A lot of what I already know and did. Thanks for a whole lot of the same!
  • 19,396 Answers
It can be the inverter, or the backlight, ar also the switch that de-activates backlight when you close the laptop.
Read here : LAPTOP MONITOR SCREEN VERY DIM OR DOES NOT ...
Posted on Oct 16, 2008
  • Ginko
    Ginko Oct 17, 2008
    Repeat? that is the solution.
    If you have dim light, as someone told you, then that means that you have either a faulty inverter, a faulty backlight, or that the AC charger is not connecting, or that the backlight is disabled in power saving mode. That is all.
    Check the power setting mode, bother to read the article here LAPTOP MONITOR SCREEN VERY DIM.. and do the test switching to ext monitor, check if light flickers, do also a test unplugging AC charger (battery must be working).
    The inverter is a small rectangular board, usually placed within the display assembly, that powers the backlight.
    The first thing to check is the backlight bulb itself (or themselves), if the bulb works it will light up when powered with 12V, following the specs. Bulb can also be tested with a multimeter, checking it for continuity.
    If the bulb is good you should test the inverter board, to know if that is faulty, you have to test specific voltages out, if there is no power out, you follow a diagram for the power stabilizer/power amp IC, or circuit, and eventually replace it again, always remember that it is very easy to fry a pcb. Inverters are usually powered at 5V , with a gap of +-.5V as in all circuits. This board is a power amp, andhas a potential power out of over 500V (500V 800V on new Acers)
    Test also the inverter pcb connector cable, using a multimeter. If you do not have a multimeter and at solder at home, that usually means you should not even work on electronics, therefore, if you do not have a multimeter buy one :
    Basic analog GB ELECTRICAL, INCORPORATED 19-Range Analog Multimeter
    Basic digital Deluxe Digital Multimeter
    Good Actron Auto TroubleShooter Digital Multimeter and Engine
    Pro Fluke 87 5 True RMS Digital Multimeter (74974)
    G.C.
    electronic engineer.
  • Ginko
    Ginko Oct 19, 2008
    Well, if you knew it already you should have just fixed it, and I would have saved my time here.
    Thanks for the bad rating given.
My back light dims when i unplug the power cord of my laptop. my brightness options show 100%
Posted on Nov 25, 2008
Screen fades in and out
I'm just curious about what make and model is your computer?
May 17, 2012 | Computers & Internet
Screen has horizontal lines and fading
bad screen u have to get new screen take it apart from top side pop off top panel 2 screw on back use flat head unscrew screen get new one one ebay ect ok cheak cables in ther also thx nick
Feb 09, 2008 | Computers & Internet
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
Jun 19, 2009 | Compaq Computers & Internet
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
My laptop screen is very dim, cannot read or see looks faded
Try using the brightness controls on your keyboard to brighten the screen. If that doesn't work then that means either the lcd or the inverter has gone bad.
Apr 14, 2009 | Computers & Internet
No light on screen of acer extensa 4620 4605 PC notebook
On your first laptop, If you see a faded image, it usually is the Inverter board. I have had great success buying from this company, great customer service:
http://www.smartmicrousa.com/acer_inverter_board.aspx
If you don't see it on the website, call them.
You may have to copy and paste the link into your browser.
On the second laptop, It seems you have replaced all components that may be causing the problem.
I would hook up a monitor to test and see if your video out is working. That would narrow it down to the LCD and or the Inverter.
Then I would check the connection on the system board and the connection on the LCD screen where the cable from the system board plugs in. It is strange that you get the same symptoms after changing all those parts. Were the parts you use for replacement new? You may have receive DOA parts.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Computers & Internet
This is a problem I have experienced with my HP laptop as well. I found some info on this and was told that it was the inverter. I managed to fix this by finding the inverter and, unplugging both ends of it and plugging it back in. This fixed the problem and a week later its still working!
The inverter is usually located at the bottom of the screen. To access it you need to unscrew the screws around the screen. This will involve removing the plastic covers and simply unscrewing them.
Once you have removed the plastic cover from around the screen, you should see the inverter at the bottom. Re-seat the connectors, and see if this fixes it. If not, replace with inverter. The site below is an example of where you can buy one.
http://www.laptopbacklights.co.uk/
This may help you with the process
http://www.laptoprepair.co.uk/how-to-repair-backlight-inverter.htm
Hope this helps, let me know
Jun 02, 2008 | Acer Extensa 500T Notebook
Try to find the button that tells the screen to come on. This sticks sometimes on laptops. I always tell people not to use canned air because it only blows dust around, but it could help your problem. If you are okay with taking it apart you can find this button and see if it is sticking. This is becoming a common problem with laptops. I recently had a customer with this problem and it took me some time to figure it out. It is usually around the hinge. Look at the manual if you can't find it.
Jun 02, 2008 | Acer Aspire 5100 Notebook
Laptop screen will not come on
What you do is when you switch on your laptop, Try to press F2 to go into BIOS or do anything so that your computer won't boot into windows. My question is incase you're in BIOS setup...can you see anything on screen ??? if no then try to look more seriosly that anything???? if no then last test is to plug external monitor..incase nothing on external monitor also then you've problem with your notebook maybe motherboard or screen problem.
Goodluck,takecare.
May 08, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
1,099 people viewed this question
David Payne
David Payne
