No light on screen of acer extensa 4620 4605 PC notebook
My laptop is coming on but i am not seeing anything on the screen. i can make out a fade out line in the back ground. I was told may be it is the LCD screen and inverter. what do u think? And how can i locate the part to order it? urgent I also have an Acer Extensa 4620-4605 laptop that will not light up.. I have tried 3 different inverters, two different lcd screens and a new cable. I even replaced the motherboard, but my LCD will not light up. I think the inverters I bought were not good or the wrong ones. I have also checked lid switch. Any Ideals or where can a person buy a new 4620-4605 inverter. Certainly not at ACER.com. I can't find anything there. HELP HELP HELP
  • jbdeckert247 Oct 17, 2008
    I did all that and still nothing and this is all just one laptop Im trying to get the screen to light up? Just parts to try and light this one up. Thanks for the link, I will try yet another (the fourth) inverter for this laptop.
  • choctawcwp1 Mar 28, 2009
    the power light comes on & stays on but, the cdrom & fan shut off after 3 seconds. the replaced the T-2310 cpu & still same problem.
  • 4,338 Answers
On your first laptop, If you see a faded image, it usually is the Inverter board. I have had great success buying from this company, great customer service:
http://www.smartmicrousa.com/acer_inverter_board.aspx
If you don't see it on the website, call them.
You may have to copy and paste the link into your browser.
On the second laptop, It seems you have replaced all components that may be causing the problem.
I would hook up a monitor to test and see if your video out is working. That would narrow it down to the LCD and or the Inverter.
Then I would check the connection on the system board and the connection on the LCD screen where the cable from the system board plugs in. It is strange that you get the same symptoms after changing all those parts. Were the parts you use for replacement new? You may have receive DOA parts.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 16, 2008
Acer extensa 5620 will power on. The battery light on with the battery and power cord. But it will light on with the just the power cord or jujst the battery.
As long as it is working OK, then the battery light, is only an indicator, A laptop should work, either way, with just the battery, or just the Power Supply, and of course both. Try adjusting you Power Settings and see if that alters anything. Also consult you manual about the issue.
Apr 08, 2010 | Acer Extensa 5620 Notebook PC
ACER EXTENSA 4620-4605 model screen problem
If you wiggle the screen and it comes back, then it is not your Video card. Probably just a loose connection with your LCD cable to the LCD screen. Although you may also need a new screen/cable.
The weird thing is that it "fades" out... which would indicate a bad screen to me.. but securing the cable is alot cheaper to try first.
Completely rule out your graphics card by connecting your laptop to an external monitor... if it works fine for a long period of time then your card is fine.
Good Luck.
Sep 06, 2009 | Acer Extensa 4620 Notebook
I Acer Extensa / AT&T usb wireless card
I had trouble too..  Go Verizon.. no trouble
Nov 24, 2008 | Acer Extensa 4620 Notebook
DIM SCREEN
It can be the inverter, or the backlight, ar also the switch that de-activates backlight when you close the laptop.
Read here : LAPTOP MONITOR SCREEN VERY DIM OR DOES NOT ...
Oct 16, 2008 | Computers & Internet
The acer 4400/4120 screen will not come on
The computer screen will not come on but the hdd light is active. Accer 4420/4120 extensa series/ just clicked on a computer because mine is not on the list
Sep 25, 2008 | Acer Extensa 710TE Notebook
Check the setting for the VGA display. Usually it's a combination of keys that include the Fn key and another key. The VGA key has a picture of a monitor by the key. If that doesn't work look for brightness dial on the laptop.
Jun 02, 2008 | Acer Extensa 4620 Notebook
This is a problem I have experienced with my HP laptop as well. I found some info on this and was told that it was the inverter. I managed to fix this by finding the inverter and, unplugging both ends of it and plugging it back in. This fixed the problem and a week later its still working!
The inverter is usually located at the bottom of the screen. To access it you need to unscrew the screws around the screen. This will involve removing the plastic covers and simply unscrewing them.
Once you have removed the plastic cover from around the screen, you should see the inverter at the bottom. Re-seat the connectors, and see if this fixes it. If not, replace with inverter. The site below is an example of where you can buy one.
http://www.laptopbacklights.co.uk/
This may help you with the process
http://www.laptoprepair.co.uk/how-to-repair-backlight-inverter.htm
Hope this helps, let me know
Jun 02, 2008 | Acer Extensa 500T Notebook
Try to find the button that tells the screen to come on. This sticks sometimes on laptops. I always tell people not to use canned air because it only blows dust around, but it could help your problem. If you are okay with taking it apart you can find this button and see if it is sticking. This is becoming a common problem with laptops. I recently had a customer with this problem and it took me some time to figure it out. It is usually around the hinge. Look at the manual if you can't find it.
Jun 02, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
1,002 people viewed this question
David Payne
David Payne
