Question about Ricoh Aficio 1035 Copier
Sc 322 on a 3045. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont understand what a synchronization error is. whats the solution to this problem??
  • 2 more comments
  • Anonymous Dec 04, 2008
    When I switch ON my copier, it givem me the error code SC322, lighting functional Problem.
    What could be the solution to it.
  • j_quinones Apr 15, 2009
    Have a Savin 4035 with the same problem SC322. Will warmup but when try to print SC322 pops up.
  • Eric Cave Jun 13, 2013
    Sc 322 on a 2035. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont understand what a synchronization error is. whats the solution to this problem
  • Anonymous Mar 24, 2014
    HAVE CHANGED UPPER AND LOWER THERMISTERS AND LOWER ROLLER
    Problem Solver:
  • 9 Answers
Another poblem with this machine is that the sync detect for the 400 dpi and 600 dpi could be off. Go into service modes by pressing the yellow clear modes key then pressing the numbers 1 0 7 then hold done the red stop key till you see the display change. Now go into copy sp, then hit the 2 in the window {drum}, next use the page down button located in the middle of the screen till you see the one that says 2109 LD Beam Pitch Adjust. Go to number 2109-8 beam pitch data reset. execute then go to 2109-1 and set it to 144 then hit pound. Now go to 2109-3 and execute. last go to 2109-2 and set it to 168 then hit pound. Now go to 2109-4 and execute. exit out of the service modes window. now try to run a copy and a print. If these fail the you either need to clean the laser assembly, a polygonnal mirror moror or laser drive unit.
Posted on Dec 16, 2008
  • hosseinireza Jan 24, 2011
    lanier 5635 copier sc322 error code
  • Ali Muhammad
    Ali Muhammad Sep 29, 2011
    thanks
  • 3 Answers
Posted on Jun 13, 2013
    Problem Solver:
  • 5 Answers
Sc 322 apears when Lasier diod unit is dirty &synchorization sensor is a sinsor in the right side of LD unit and it my be a dirty so it dosent sens the lasier ***** or replase L D U
Posted on Oct 19, 2008
  • Ali Muhammad
    sc 322 error code problem with me
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
Sc 322 on a 2035. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont...
SC 322 - 1st laser synchronization error.Poor cable connection between the laser synchronization detector board and the LD unit.Laser synchronization detector board out of position and angle of reflection not correct.Laser synchronization detector board defective or LD unit defective.Try to change the LD polygon motor unit(90% defective).
Dec 30, 2013 | Ricoh Aficio 1035 Copier
Canon pixma ip4600 says it cant print bc theres not paper, but there is. i cant figure out how to print.
Many times the switch that lets the printer know it's out of paper is stuck in position, or dust has clogged it. If you can blow the small bits of paper or dust out you can get it going again. I use a can of compressed air to clean my printer about once a month to stop this from happening. It is a common problem.
Jul 23, 2017 | Canon PIXMA iP4600 Color InkJet Photo...
When you send something to print it stops, the attention light blinks red and once you click on the green CHECK button it prints again. Why does it act like its jamming?
  1. Slide the paper-width guide to its widest position, and then pull out the paper tray extender. Figure 2: Move the paper guidesc00648140.gif
  2. Insert plain white paper into the input tray with the short edge forward and the print side down. Slide the paper forward until it stops. Figure 3: Insert paper into the productc00636180.gif
    CAUTION: Make sure the product is idle and silent when you load paper into the input tray. If the product is servicing the print cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages.
  3. Slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Adjust the paper guidesc00636178.gif
    NOTE: Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Nov 09, 2010 | HP LaserJet P3005n Printer
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Canon mp160 fault code E27
Solution that WORKED!!!
NEW REDACTION!!
pineworks Rank: Guru canon.gif computers_small.png Expert Rating: 87%, 1202 votes Hi there Canon printers MP 160 AND MAYBE OTHERS A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
B) E27 - it is code for reset absorber (EEPROM reset or Waste ink counter reset) and follow the described below procedure: With the printer powered off but connected to a power source,
1) First..while pressing and holding the Stop/ Reset button, press the Power button..do not release the Power button 2) Wait till the Power light is ON, then while still pressing the Power button... press the Stop/Reset button two times (visible for alert-orange-LED lights on & off). 3) When releasing both the Power button and the Stop / Reset button (regardless of order), the printer will move into the service mode. Waiting for menu selection visible for:
  1. On/off light is fixed green
  2. Display shows "0"
  3. A4/Plain paper light is fixed green
4) Being in this Service mode, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.
  • Each time the Stop/Reset button is pressed, the 2 LEDs (A4<>Alert) switch alternately into orange and green, starting with orange.(Note: press 4 times for waste ink counter reset).
The number of Reset button pressing: 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset 5) Turn off the printer.( it must be turned off)
then turn it on again. Only in B) case you can enter into "service mode", in A) case if have e.g. paper jam, or another error you CAN'T enter the "service mode" Try it
THANKS..JUST GREAT!!!
Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
My problem with the Lexmark optra sc 1275
Lexmarks use a silicone oil cleaning pad on top of the fuser, try to locate a door on top towards the rear, take it out you might see a long black piece, when you take it out it has a felt on the bottom it is used to clean excess toner off the fuser it should be replaced everytime you change your toner ( usually comes w/the toner).
Oct 11, 2007 | Lexmark Optra SC 1275 Laser Printer
Ricoh Aficio 1035 Copier Logo
2,813 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
