Washing machine problem
I have a servis washing machine and the washer is working when you put three items in it, but if i put more in the washer the drum wont go round. the program seems ok because the drum fills with water then it goes through the cycle fine and spins fine it's just on the washing bit when the drum tries to go round but carnt please help
  • Washing Mach... Master
  • 19,396 Answers
That means that there is either a problem with the belt, or with the drum bearings.
The machine should be inspected by a technician.
If you want to get repairs for your appliance you can call the number listed on the owner manual.
Posted on Oct 16, 2008
Hi, i have a servis washing machine M6704w that the drive belt came off. I have put it back on but when I swich on at the socket there is no display on the panel. I can hear the door lock close and open...
NOT SURE BOUT THIS MODEL BUT ON DRYERS WHEN THE BELTS COMES OFF THEY HAVE A BELT SAFETY SWITCH THAT SHUTS DOWN THE MACHINE, PERHAPS THIS WASHER MAY WORK ON A SIMILIAR BASIS? OTHER WISE i WOULDS SAY U HAVE ABAD FUSE SOMEWHERE? CHECK THE PANEL
Mar 23, 2015 | Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
press the half-load button when you need dryer to work, make sure wash dial is at end position
Feb 03, 2010 | Servis Dishwashers
What holes
Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
Jul 27, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My servis m6755b washing machine door wont open
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Washing Machines
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
New washing machine servis M6725,dispenser drawer will not open.only got it yesterday
i have just used my servis washing machine 1300 aa and just went to put a new load in and there is no power to the machine at all i have checked the fuse and the plug wiring what else can i dp please advise???????
Jul 29, 2008 | Washing Machines
Changing door gasket on Servis M9813s washer dryer
you can clean in situ just as good as if you remove it
Jul 12, 2008 | Washing Machines
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Servis washer/dryer
Leaking all the time or just when it is in certain cycles?
Feb 10, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
