Question about HP Computers & Internet
My hp dvd writer300i won't accept the disk formatts that it used to accept why??? i was using Hp brand dvd r 4.7gb disks now they aren't working why????
    Master:
  • 538 Answers
Could be a capacity issue and driver integration...check with the hp specs..
Posted on Oct 16, 2008
8gb kingston micro sd
Kindly Check if the memory card is password protected, if it so then unlock it first. then try format in phone if wont works then try using computer / laptop . Backup data if need in it first then using direct format by right click the memory card on my computer on windows system then click format. Another method is try using HP disk formatter software.link:
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
Jun 08, 2014 | SanDisk Electronics - Others
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
Recovery discs aren't working on my hp cq60-615dx, what should I try next?
Appears that recovery disk #2 is bogus. U can try to get a new set from HP (fat chance!) or you can do a reload from a normal, retail OS disk.
Jun 17, 2017 | HP Presario Computers & Internet
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
HP LaserJet M5035 MFP
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
HP DVD writer 1140D doesn't recognize DVD's thinks drive is empty. Research on driver versions shows it's using Microsoft drivers. I would like to have the HP drivers to download that came with the DVD but...
all dvd writers have drivers on windows...and are installed automatically when windows is installed..If it started not to recognize dvd-es ...specially the ones burned in data format with multiple movies (avi ) ..even burned on it ...but sees the original ones..or sees the cd'es ..than the issue is with its lens ..and either you need a cleaning disk to clean it up ..or it is gone ...and need to be replaced..I personally have to do with something like this sand tried to update firmware ..installed original driver from the support site ,,and all the same ..Clean the lens and see how it is behaving ..and if it does the same ..just replace it ..cause they do have limited life time..otherwise you will end up with a lot of frustrations and no results...
Mar 18, 2011 | HP DVD1140i 22x Pata Multiformat Dvd...
I want to restore my pc to its factory settings
Take the original "System Restore" set of CD/DVD disks that were shipped with your computer, and reinstall Windows.
Some brand-name manufacturers (Dell, IBM, HP, COMPAQ) will accept telephone-orders for that set of disks, to match the disks that originally were shipped with the computer.
Sep 27, 2010 | Computers & Internet
Issue with opticaldrive and creating factory default disc
most of the time to create recovery disks you have to use about 7 cds, 2 DVDs, 1 blueray or double layer. some systems also use DVD+R, when you start the disk creation it would tell you what it requires, your best option (if compatible) would be using 2 DVDs-R. On the other hand if you inserted the cd and it turned a few revs. most likely it is ruined already so you have to use a new disk.
if it is a brand new pc you should be able to use DVD. here is a tutorial for HP and it is pretty similar for most computers
http://www.wikihow.com/Create-Recovery-Discs-for-Windows-Vista-in-HP-Recovery-Manager
if it works for you don't forget to rate me
thx
Apr 28, 2010 | Gateway Computers & Internet
HP Pavilion dv5-1125nr entertainment PC Notebook
no OS stated, is this XP?
my guess you are using the HP backup or ?some HP software to do that, you never said.
the day to do that is day1, not 10 years later
you will end of with a useless disk in any case.
back new in 2008, long ago, the Laptop has this card inside,
instructions saying to make a recover disk, now,
that will work then, but now, 9 years later.?
how can it?
if XP its a corrupted OS and now is not supported.
same now with VISTA.
your PC came new with Vista or 7 (both 32 bit or 64)
what is there NOW.
the building a recovery disk needs all things perfect.
1: OS not corrupted,
2: recovery partition not corrupted or missing
3: DVD drives still good, and correct media used.
4: Driver for the DVD must be correct. from HP.
5: HDD must be bad, and passes the S.M.A.R.T tests.
one trick to get there is push the F11 key.
that is the HP recovery magic key (power on hammer f11,,, bam)
then recovery the OS then make the recovery disk.
now that the OS is ok , the DVD-r (or what it needs) will work.
if the F11 key fails, that means the HDD is bad or the recovery partition is corrupted, as most are this old.. 9 long years later.
Oct 29, 2017 | HP Pavilion dv5-1125nr Notebook
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
