Question about BenQ FP731 17" LCD Monitor
BENQ FP731 I have just received a used BENQ FP731. From my son. It was working very well on his system. I have plugged it into my laptop with no results.Does it require a specific download program?
  • JDTec
    JDTec May 11, 2010
    Did you change the function by holding the Fn key and pressing the key that says crt/lcd?
    the crt/lcd key is on the upper row of the keyboard. It may have an image of a "double" monitor.
  • 153 Answers
Just leave the monitor for a while about an hour and try connect and see, if not displaying than Try changing the display resolution from your laptop and see what happens.
Posted on Nov 19, 2008
I have a 15 inch BenQ FP731 monitor and its been working all fine for the past year, until yesterday. I have an Acer laptop hooked up to the monitor as its screen was wrecked so I just kept the display on...
This because your ACER laptop having higher resolution than your monitor. Please lower your ACER laptop resolution as low as possible then try again.
Aug 06, 2011 | BenQ FP731 17" LCD Monitor
Where can I find instructions on replacing the backlight on benq fp731?
jsiwiec, Are you absolutly certain that the "cold-cathode-fluorescent-lamps" need replacing, or if the "switch-mode-power-supply"/"CCFL inverter supply" is not working and is in shutdown mode? CCFL's are not some kind of miniature version of those energy efficient screw-in new style, curlie-Q cfl light bulbs you buy at the local home-center!!! In any case here are some places to checkout first. , , ,, You do know that most times the problem is not the lamps. Did your LCD display have bright, crisp, colorful images displayed on the lcd panel 2- 3 days before black screen happened? How many TOTAL "ON" hours of use on this BenQ FP731 ? When was unit produced? Good luck with repair. Hope info was helpful.
Mar 12, 2010 | BenQ FP731 - 17" LCD Monitor
Monitor no longer works with the desktop, only with the laptop!
Maybe your new monitor don't supports the signal of your computer. Try finding another one, or otherwise, buy a graphic card, that will be supported from your monitor.
Hope this solve your problem!!
Jun 13, 2009 | BenQ FP731 17" LCD Monitor
Benq FP731 LCD not start up, only green power lamp
Opening it will not likely solve your problem. Have you tried another monitor on the computer to see if the problem may be with the computer itself?
Mar 04, 2009 | BenQ FP731 - 17" LCD Monitor
Benq screen resolution auto adjust seems to auto adjust wrongly
I would recommend you to bring it back and get a new one, if its till under warranty. You cannot fix the problem on the panel buttons it looks something to do with the components in the circuit bord.
Nov 19, 2008 | BenQ FP731 17" LCD Monitor
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
How to take apart a benq fp731 lcd monitor
You remove the 5 screws behind and using a plastic card inserted between the front and back plastic frames gently prise it open.
Careful!!! High voltages inside.
Feb 21, 2008 | BenQ FP731 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Jan 15, 2008 | BenQ FP731 17" LCD Monitor
Benq FP731 17" monitor goes Blank after start up
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
Aug 09, 2007 | BenQ FP731 - 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
211 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
