Question about Kitchen Ranges
Maytag Gemini top oven, the bottom element does not get hot. I replaced the element with a new one from maytag. what is the problem?
  • 750 Answers
Hello jrlibs
Welcome,
You said, Your Maytag Gemini top oven, the bottom element does not get hot. You replaced the element with a new one from Maytag. Asking what is the problem?
1.What is the model number and the year of your Gemini Range?
2.Was there an error code that came up before you changed the heat element?
3.If yes what was the code?
4.Did you check for current in the connection leading to the element before you installed the new one? Or just plug it in hoping for the best?
Waiting for your reply!
Huuum
Posted on Oct 16, 2008
Bottom oven on Magtag Gemini burning bottoms of everything
when you set oven on bake the broil element comes on too,set the bottom oven on broil and see if the element gets hot,if not,unplug the machine or kill the power going to it,remove the element and check it with a meter to see if the element is bad,if so change out broil element if element is good you could have a broken wire or bad clock assy.there's a computer board with the clock that everything runs through,hopefully you have a bad element,if the element is coming on next thing to check is the sensor,this tells the computer how hot it is so it will turn the elements on and off,if you look behind the top panel in the back i think the paperwork is in a plastic pouch,it will tell you how to read out the sensor,i think it's 1080 ohms,or you can read out the sensor on the top oven and then check the bottom sensor and hopefully it will be a bad broil element or sensor and not the clock assy. hope this helps.
Feb 27, 2013 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Bottom oven heating element turned white hot and broke in the middle. Can I replace myself?
This is a common problem and easy repair. Locate the model number onside the oven door frame. Purchase the element based on the model number. TURN OFF the power to the oven. Unscrew the 2 screws inside the oven holding the element to the back wall. Gently pull the element forward. The wires will be short.Remove the wires from the broken element. Place them on the new element. Re-insert the element terminals and attach the screws.
TURN ON the power. Bake me some cookies and send them to me.
Jul 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Problems with Maytag MER6772 Gemini Electric Kitchen Range
may tag gives 5yer worenty if not still under worant get rid of it
Apr 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Oct 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
2001 Gemini electric double oven
you can remove them from the inside.after you remove two screws.(one from each side of the element) pull it out slowly so that you dont disconnect wires from the element. if wires disconnect then you have to pull ou the oven and unscrew back panel to reattach the after you install the new element.
Feb 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemni Stove
The problem is either in the oven control or the element (in some cases could be both). You will need a meter to check the resistance on the elements as well as power to the element. Remember this is 240 volts and very dangerous. If your not comfortable with it call a professional.
Oct 08, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
452 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
