Defragment does not work
Hi, I have window XP pro version 2002 service pack 2, Dell 8400
I got a little computer problem.
I lost defrag in my start, all program, accessories, system tools, defrag.
Also lost it in start, my computer, right click local disk (c:), property, tools defrag.
When I click on the defrag in either area this is what I get in a pop up blue box..
Microsoft Management Console
MMC cannot open the file c:windowssystem32dfrg.msc.
This may be because the file does not exist, is not an MMC console,
or was created by a later version of MMC. This may also be
because you do not have sufficient access rights to the file.
But if I go to
Start
Run
type in, Compmgmt.msc
Then click on, Disk Defragmenter
Then it'll run this way. My question is, how in the heck can I get itback and recognized in those first two areas that I mentioned? It hasalways worked in there, and I haven't a clue as to why it is no longerbeing recognized. Can you help me out????
I HAVE WINDOWS XP. For months now I have been unable to disk defragment thru - START - THEN CLICKING ON DISK DEFRAGMENT. When I try the following pops up?!?!?
MMC cannot open the file C:WINDOWSsystem32devmgmt.msc.
This may be because the file does not exist, is not the MMC console, or was created by a later version of MMC. This may also be because you do not have sufficient access rights to the file.
  • 2 more comments
  • LUISA Oct 17, 2008
    I COULD NOT FIND THE "windows\inf" FOLDER THEREFORE I COULD NOT FIND THE "dfrg.inf" FILE. WHAT DO I DO NOW?!?!? DO I JUST DOWNLOAD THESE FROM THE INTERNET???
    I HAVE TRIED RESTORE SYSTEM BUT STILL NOT WORKING. HOW WOULD I GO ABOUT REPAIR INSTALLATION???
  • LUISA Oct 19, 2008
    WHAT IF I DON'T HAVE A CD. CANNOT FIND IT - MUST HAVE MISPLACED IT WHEN WE MOVED.?!?!?
  • Puneet Jain
    Puneet Jain May 11, 2010
    Could you please send me a Hijackthis log of your PC.
    http://www.trendsecure.com/portal/en-US/...
    Send it to techin.scott at the gmaildotcom
    I would like to analyse your PC, also let me know the PC Configuration (All hardware details)
    Have you noticed since this happened after a specifc thing (viz after installation or removal of any application etc)
    May be some sort of virus infection, and corrupt window.
    Reply me so I can figure it out.
  • 16 Answers
Go here
http://support.microsoft.com/kb/907265
scroll halfway down and click the link...or click this if you can on this site.
http://www.microsoft.com/downloads/details.aspx?FamilyId=61FC1C66-06F2-463C-82A2-CF20902FFAE0
download and install.
your fixed.
i just had the same problem and it worked for me.
Posted on Aug 10, 2009
    Guru:
  • 558 Answers
I would suggest you to go for Roll Back PC on previous date. Do a System Restore to the date you think system running better. Otherwise it would need repair installation of Window with the Recovery or Installation CD of win XP.
Regards Ellin
Posted on Oct 17, 2008
  • 2 more comments
  • Puneet Jain
    Puneet Jain Oct 17, 2008
    These are the steps you need to follow with your Operating system and also having the Recovery or Installation CD:
    Repair a Damaged Installation
    Please note: If you make a mistake when following the steps below, you will not be offered the option to repair a damaged installation. Follow these steps precisely (or reboot from the CD and start again).
    1. Boot from the Recovery CD (press any key when prompted).
    2. Choose Setup (press ) - do not choose the R=Recovery Console option.
    3. Press F8 to agree to the license agreement.
    4. Press R to Repair the selected Windows XP installation.
    5. The setup program will copy files to your hard disk and reboot automatically.
    6. Do NOT press any key when the CD boot code is run, allow the code to timeout, the system will boot from the hard disk and continue with the installation from the CD.
    7. Answer the configuration questions once the computer has finished re-installing. You will be prompted for your Product Key which you will find at the back of your system. You will also need to Activate your system within 30 days, if you have not done so previously (see below).
    After this please let me know and give the solution atleast Helpful rating
    Have a Nice day,
    Ellin
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
  • Puneet Jain
    Puneet Jain Oct 20, 2008
    If you dont have CD, then I would suggest you to take it to repair shop, where the engineer can load the Window with his CD. Go to your nearby Repair shop.
    Thanks for using FixYa and voting the solution.
  • Puneet Jain
    Also you can try in this last moment before going to Repair Shop.
    Press F8 during bootup, a black screen shows with options to select.
    Select if view the option that says: Load to Factory setting or Load to Restore Default (If i am correct in stating)
    Check whether running this where you can go (most of time window itself load without CD to the state when it is purchased new)
    Regards,
    Ellin
  • 4,338 Answers
You need to re-register the defragmenters snap-in files, and the basic registry entries.
  • First open up a Command Prompt, this can be found at:
    Start -> All Programs -> Accessories -> Command Prompt
  • Change into your windows\system32 directory. Your windows directory will be either windows or winnt. Type:
    cd \windows\system32
  • Register the defrag components, by typing:
    regsvr32 dfrgsnap.dll
    regsvr32 dfrgui.dll
  • At this stage, you may find the defragmenter works. If not, there is one more step you can do.
    Using Windows Explorer browse to your windows\inf folder.
    In there you will find a file called dfrg.inf right click this file, and select Install.
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Posted on Oct 16, 2008
  • JDTec
    JDTec Oct 16, 2008
    I also found this that may help:
    Anyone getting the "Disk Defragmenter Could not start" message and on Windows XP Home This is what worked for me. Go to Control Panel, Select System and select the Advance Tab. Now Select Settings Under Performance and again select the advance tab. Under Virtual Memory select Change. Make sure that the Paging File Size for selected Drive for the Drive partition you want to Defrag has either a custom at least 2 times the amount of installed RAM if the space is available or is set to System Managed Size. Once I did this Defrag started working again. I don't know how the Page file got turned off on my system but this has been driving me mad for months!! Hope it helps someone else out there !!!
    Thanks to JB.
How can i defrag my dell optiplex 380
Here's how you can defragment your disk:
Windows Vista, 7:
  1. Open Disk Defragmenter by clicking the Start button . In the search box, type Disk Defragmenter, and then, in the list of results, click Disk Defragmenter.
  2. Under Current status, select the disk you want to defragment.
  3. To determine if the disk needs to be defragmented or not, click Analyze disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    Once Windows is finished analyzing the disk, you can check the percentage of fragmentation on the disk in the Last Run column. If the number is above 10%, you should defragment the disk.
  4. Click Defragment disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Disk Defragmenter might take from several minutes to a few hours to finish, depending on the size and degree of fragmentation of your hard disk. You can still use your computer during the defragmentation process.
Windows XP:
  1. Open My Computer.
  2. Right-click the local disk volume that you want to defragment, and then click Properties.
  3. On the Tools tab, click Defragment Now.
  4. Click Defragment.
For more information refer to these links:
http://windows.microsoft.com/en-in/windows/improve-performance-defragmenting-hard-disk#1TC=windows-7
http://support.microsoft.com/kb/314848
GuruAid.com
May 18, 2014 | Dell OptiPlex Computers & Internet
Tip
How to defragment your computer
Defragmenting your computer is a very good way to keep your computers hard drive working correctly and healthy.
Follow these very simple steps below:
1. Click on "Start".
2. Now click on "My Computer".
3. Now right-click on the hard drive you wish to defrag.
4. Now click on "Properties".
5. Now click on "Tools".
6. Now click on "Defragment Now".
7. Now another dialog will come up click on choose the hard drive yet again, then click on "Defragment".
8. Now let it defrag (this may take a while depending on your computer speed.)
It's best defragmenting your computer maybe once every 2 weeks.
on Oct 24, 2007 | Microsoft Windows XP Professional With...
How do i clean out my computer to speed it up
Follow these guidelines to speedUp pc:
  • Defragment the Hard Disk
  • Defragment the System Registry
  • Clean the Temporary Stuff and Browser Cache
  • Remove Obsolete Registry Entries
  • Disable Startup Programs & Services
  • Customize Windows for Best Performance
  • Uninstall Programs and Disable Windows Features
For an instant fix use system optimizer PCFresher.
Jan 18, 2013 | Dell Computers & Internet
How can I defrag my Dell optiplex760?
How to Defrag a Dell Computer
1. Open the My Computer window. To do this on a Dell computer, click on the "Start" button at the bottom of the screen. Then, click "My Computer".
2. Choose the hard disk drive that you want to defrag. Locate the section entitled "Hard Disk Drives." In this section is a list of hard drives on the computer. For most Dell computers, the hard disk drive you will want to defrag is Local Disk (C:).
3. Right-click on the hard disk drive you want to defrag on the Dell computer. If you want to defrag your C: drive, then right-click on "Local Disk (C:)". A menu bar will appear.
4. Click on "Properties." "Properties" is the last option on the menu bar. This opens the Local Disk (C:) Properties window.
5. Click the "Tools" tab. The Tools tab is the second tab in the Local Disk (C:) Properties window. The tabs are located on the top of the window.
6. Click the "Defragment Now" button. The "Defragment Now" button is in the Defragmentation section of the window. This opens the Disk Defragmenter window.
7. Click to select the disk drive you want to defrag on a Dell computer and then click "Defragment." For most Dell computers, this will be (C:). After you click "Defragment," the Dell computer will first analyze the disk drive you selected and then beginning defragging the Dell computer.
8. Wait for the "Defragmentation is Complete" message. If you have not defragged a Dell computer in a long time, then the defragging process might take a while, even as long as an hour for very fragmented Dell computers. Allow the Dell computer to run the defrag until the process is completed. You will know that the Dell computer has completed the defrag process when the "Defragmentation is Complete" message appears.
9. View the defrag report and then close the window. If you want to view the defrag report, click "View Report." Otherwise, click "Close" to close the window.
Jun 26, 2011 | Dell OptiPlex 760 MT Desktop Computer
How do i defragment my laptop
right click the hard drive and choose properties.
within that new winow there is a tab called Tools.
There will be a section under the tools tab called drfragmentation.
Mar 01, 2011 | Toshiba Satellite Pro L450 Notebook
Is Windows xp professional version 2002 service pack 2 is not xp home service pack 2. is this compatible with sql server 2005? Thanks
All Service Pack 1, 2 or 3 for XPs are for Pro & Home Edition and are not meant for other Windows Version!!
As for SQL Server 2005 you can get your Latest Updates & Service Packs @ http://support.microsoft.com/kb/913089
Hope it helps.
Oct 02, 2010 | Computers & Internet
How do I defragment my XPS One
I assume you mean hard drive defragmentation. In Windows, double click on Computer (My Computer in XP), right click on your hard drive ( C: drive) and go down to Properties. Click on the Tools tab and the Defragment Now button. A disc analysis and defragmentation window will open. Click again on the C: drive to highlight it and click defragment disc. If you have Win7 or Vista, this is actually automated and you can change the time that it runs (the default is 1 am Wednesdays).
I hope this helps.
Feb 28, 2010 | Dell XPS One All-in-One TV Desktop with...
My pc is extremely slow, I have even formatted and instal a new version of Windows Xp service pack 2 to my PC pentium-3 with 256 RAM but there is still no change. Need some one to help me out.
slow pc is the cause of many problems.
1=firstly,use disk cleanup.
2=secondly,regularly defragment your hard disk.
3=thirdly,try to switch over to pentium 4 3.0 Ghz or intel core 2 duo.
4=at last,change your motherboard to ddr2 Ram supporting Board.
Dec 30, 2008 | Intel Celeron 2.4Ghz Socket 478 CPU (...
This problem can be tacked in a few ways. But I cannot guarantee that it can solve the problem. So please do try out all the alternatives shown below one at a time.
  • Go to Start and then Run, type regsvr32 msxml3.dll and run it, or
  • Start --> Run, regsvr32 dfrgsnap.dll and start - Run, regsvr32 dfrgui.dll and then click on OK, or
  • Go to Start - Run and then type sfc /scannow. (If it asks for the installation CD, insert it) or
  • Install the latest MMC 3.0 (Available at Microsoft site) or
  • Browse to C:\Windows\Inf (Assuming C drive is your OS drive), right click dfrg.inf file and click on Install.
If the above does not solve your problem still, then try renaming the dfrg.msc file to something else and place the shortcut in your start menu.
If everything fails, it can only be a registry or a .MSC association problem...
Jul 23, 2008 | Microsoft Windows XP Professional
Very very slow laptop
try following:-
  1. defragment your hard disk
  2. stop unacessary services
  3. stop loading un nacessary progrsmmes to load at startup by going to "msconfig command
  4. right click on empty space of yoyr screen click properties select none in the field of wall paper and screensaver.
  5. go to computer properties by right clicking on my computer icon click "advansed" tab ,click settings under the tab performance and select adjust for best performance
  6. increase RAM
Nov 25, 2007 | Computers & Internet
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
