Question about RCA Lyra RD2011 MP3 Player
  • beardog205 Jan 25, 2009
    Will not connect to the computer through the USB port. Will not turn on even with a fresh battery.
Does the computer show a device is connected when it's plugged into the computer?
Posted on Sep 22, 2009
I have had this rca lyra mp3 player for along time and its been setting idle a few years .I put a fresh battery in it and it wont come on .Im wondering if i forgot how to turn it on .I was holding the on...
hi Arnie, 1. make sure you put the battery in right way first before I can help further.
2. for this player to come on you just push play button(which is a on button,if you push it again meaning you pause) and if you push stop button meaning is stop and if you hold on it for few seconds the player goes off.
Jul 01, 2010 | RCA Lyra RD1071 MP3 Player
MP 3 player is frozen - removing battery doesn't help
You will be able to restore the functionality of you Lyra after you reinstall the firmware you can download from the manufacturers website. This is a very common problem for mp3 players.
Here are the instructions once you have downloaded the file.
We highly recommend you do not connect your player to the computer until Step 3.
  1. Locate the downloaded RD2010/11/12/15 upgrade file and double click it.
  2. Following the onscreen instructions, allow the program to completely install all USB drivers (Windows 98SE and Windows ME) as well as the upgrade program and firmware. You may be required to reboot once the install is complete.
  3. Connect your RD2010, RD2011, RD2012, RD2015 to the PC using the USB cable.
  4. From the “Start” menu, select “Programs” > “Lyra™ Personal Audio Player” > “RD2010, RD2011, RD2012, RD2015” > “Update Device.”
  5. After the program is finished searching for the device, drivers and new hardware may be detected and installed. Then the “Update Lyra™ (RD2010, RD2011, RD2012, RD2015) Device” box will pop up with current version and new version (1.51) of firmware shown.
  6. Press “Start” to update the firmware of your Lyra™ RD2010, RD2011, RD2012, RD2015. Depending on your existing firmware version, the Upgrader might show an option for formatting the device. Click “Yes” to continue.
  7. When the update is complete, click “Close.” If present, use the Windows system tray icon to safely disconnect the Lyra™ RD2010, RD2011, RD2012, RD2015 and unplug it from the USB cable.
    Your update is now complete.
I hope that helps.
Nov 24, 2009 | RCA Lyra RD2010 MP3 Player
I have a mp3 rca lyra radio and mp3 player. It
Do you have the RCA LYRA PEARL, with the folding out usb plug? RCA has made bunch of different mp3 players and has reused the LYRA and the PEARL name. Mine has both names on it, and the firmware file below is for model numbers TC- or TH-1602 or 1604.
One time I replaced my battery and my unit would not go any further than the Pearl logo. So, I downloaded the firmware upgrade from, and followed all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again.
Nov 24, 2009 | Audio Players & Recorders
Delete songs
Plug it into a computer with a usb cable and it should show up as a removeable device and then delete the songs you no longer want.
Jan 21, 2009 | RCA Lyra RD1072 MP3 Player
MP3 player does not turn on
It looks like you need new battery.
May 26, 2008 | Thomson Lyra PDP2842U MP3 Player
Wont play unless it is plugged in
Hi, I would suggest that the Battery is faulty.. a common occurrence I have found... Try a brand new or fresh charged know good battery.. I think ya may find thats the culprit.. Also check & clean the Batt Cons inside the unit.
Aug 04, 2007 | RCA Lyra RD2840 MP3 Player
My rca lyra rd1080b
this is the best solution you have update your lyra rd 1080/rd 1090 for download the updating click her and after instaling this update follwo instructions provided below ? To update your Lyra RD1080/RD1090, make sure you have it connected to the computer via the included USB cable. You will need to make sure that no external memory has been inserted and the Lyra RD1080/RD1090 display reads: "USB Connected Int. Mem". (If it does not, please refer to the users guide for the section on how to switch between internal and external memory.) ? Once connected, locate and run the Lyra Systems File Update Utility if it didn't open automatically. Installshield Wizard will have automatically created this icon on your desktop as well as under "Programs", "Lyra Personal Audio Player", "RD1080/RD1090" in your START menu. ? Click the "Refresh" button until the RD1080/RD1090 player shows up under device. ? Once displayed, highlight the drive letter by clicking on it, and click the "Update SYstem Files" button. ? When successfully completed, you will see the message, "The Lyra Personal Audio Player Device system files were successfully updated." ? Click the "OK" button, and then "Done". This will close the Lyra Systems File Update Utility. ? Disconnect the Lyra RD1080/RD1090 from the USB cable, turn the unit off and back on.
Apr 22, 2007 | RCA Lyra RD1080 MP3 Player
RCA Lyra RD2011 MP3 Player Logo
214 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
