Question about Osicom NetPrint 1000 Print Server
Initial programming for a NetPrint N500E
How do i reset the unit and setup a new IP address in it?
2 Suggested Answers
SOURCE: NetPrint 1000
Hello everyone,
I've spent the past several hours getting my NetPrint print servers to work on my network & print from Windows XP.
Guess what? I've got the solution.
I have both the NetPrint 50 model and the NetPrint 1000 model. I only got the NetPrint 50 to work. I think my NetPrint 1000 may be shot. Also realize that there were a number of company acquisitions (DPI / Digital Product Inc., Osicom, Sorrento), so there is little to no information left on the Internet regarding these print servers.
Here is what you need to know:
1.) Take the cover off the print server. On the left and right sides there is a little tab that holds the case together. Get a flat-head screwdriver and apply it to either the left or right side along the seam.
2.) Jumper pins. On the NetPrint 50 you want: Auto; 10BaseT. On the NetPrint 1000 you want: 10BaseT; Auto; Tx; Factory (Jumper 10). Remember, I couldn't get my NetPrint 1000 working.
3.) IP Address. The NetPrint print servers use BOOTP to obtain an IP address. Realize - this is an older version of DHCP, but NOT the same thing as DHCP. Some DHCP servers are backwards compatible and support BOOTP. Fat chance, though. My wireless router only has a DHCP server. So, obtaining an IP address automatically is likely far too difficult / impossible. What you will need to do is assign an IP address to the unit. We cannot use DHCP to do this, and we cannot remotely access the unit (web server / Port 80 is not listening on my units). To assign an IP address to your unit, open up a DOS / CMD prompt (Start->Run; type: "cmd" and hit OK). We will be using the ARP command, which stands for Address Resolution Protocol. This is the protocol that translates between IP addresses and MAC addresses.
a.) Select an IP address you want to assign to the unit
b.) Ok, now look at the bottom of your unit and find the MAC address; it begins with two zeros.
Now enter this command:
arp -s 192.168.0.16 00-40-AF-18-61-40
replace 192.168.0.16 with the IP address you want to assign to the unit. Replace 00-40-AF-18-61-40 with the MAC address found on the bottom of our unit.
What we just did was tell your computer that anytime we send data to that IP address, it will actually send it to that MAC address, which is your unit. Ok, good job.
Now type: arp -a
and you should see and verify your entry. If you made a mistake, type: arp -d 192.168.0.16 to remove your entry.
Now, your NetPrint print server has no idea it's just been assigned an address. And it won't know to respond to that IP address unless we make it listen on that IP address. This is easy to do. All you have to do is ping the unit. Don't worry if the unit does not reply to your pings. Simply pinging it will make it realize it needs to listen on that IP address. So, type this command:
ping 192.168.0.16
Done. It's now listening on the IP address you just assigned it.
4.) Setup Printer in Windows XP. Ok, go to Control Panel -> Printers and Faxes. Add a Printer, select a Local Printer (uncheck plug-and-play). When it asks you to select a Printer Port (it will default to LPT1)... select Create New Port -> Standard TCP/IP Port. Hit Next. Now it will ask you for the Printer IP Address and Port Name: Enter the IP address you just assigned to your unit; the Port Name can be anything you want... this is just a string that uniquely identifies this printer port on your computer and it has nothing to do with the printer or print server itself (I used "RyansNetPrint"). If it asks you for what type of Network card, just select Generic. Select the Printer driver for the printer you have hooked up to your NetPrint print server.
5.) Setup LPR & Queue Name. We need to reconfigure this for it to work. Ok, Now under Control Panel->Printers and Faxes - right-click on your newly created printer and hit Properties. Click on the Ports tab. Highlight your newly created printer port (ie, RyansNetPrint) and the Configure Port button. Windows defaults the Protocol to RAW. This won't work on your NetPrint print servers. You need to select LPR. Now, the one last thing you need to do is enter the proper Queue Name. The Queue Name format is: "PORTn" Where n is the Port Number (probably 1 or 2) on your NetPrint print server where you connected your printer cable. My NetPrint 50 only has one port, so my Queue Name is "PORT1". This is where I found the Queue Name information: "http://www.brooksnet.com/faq/210-04.html". Realize - I couldn't get my NetPrint 1000 to work properly. I think it uses different Queue Names. For instance, I tried "PORT10001", "10001", etc... to no avail. I gave up and used my NetPrint 50 since it worked easily with the instructions I just gave you.
Now hit OK, click on the General tab, and click Print Test Page. Walaa!
Hope this helps you. Took me a long time to figure all this out.
Ryan
PS. the arp -s command is only peformed on your local computer. When you ping your unit. When you reboot yoru computer, the arp -s record your created will disappear. So, they key here is - my wireless router remembers what IP address goes to what MAC address (because I pinged it). Now, if my wireless router is powered off - it forgets that information. So - if you reboot your wireless router / network router / switch / hub... you will need to reenter the arp -s command and ping your NetPrint print server again to assign the IP address again. Not perfect, but it works.
Posted on Jun 08, 2008
How can I reset the password for my D Link 601 router? I connected to it with a different laptop and it seems to have set its own password. We can't connect any new stuff (Nook, iTouch, etc.).
plug the cord of the router and press the small button with a paper clip or anything that can insert to the hole of a reset button.. press it for 5-10sec then access your router on the address bar with their corresponding router's IP address..
hope it help.
Sep 07, 2011 | Computers & Internet
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Step 1:
Step 2:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Jan 10, 2010 | Toshiba E-Studio167 Copier
Osicom NET500E/N - Lost PassWord, How Do You Reset
Product NETPrint
Version 500 E/N
Method Telnet
Reset the device and then try this:
User ID sysadm
Password sysadm
Level Admin
Aug 24, 2008 | Osicom NetPrint 500 Print Server
NetPrint 1000
Hello everyone,
Now type: arp -a
ping 192.168.0.16
Ryan
Oct 28, 2007 | Osicom NetPrint 1000 Print Server
Setting IP Address
Really need a bit more information, like operating system for a start, but here goes: I am guessing that your subnet mask is different from your printers. What address that you set are you getting from the printer? On your PC, what is your IP and subnetmask set to?
Aug 10, 2007 | Osicom NetPrint 1000 Print Server
Osicom NetPrint 1000 Print Server Logo
105 people viewed this question
Top Osicom Computers & Internet Experts
David Payne
David Payne
Are you an Osicom Computer and Internet Expert? Answer questions, earn points and help others
