Question about Kodak EASYSHARE 5100 All-In-One Printer
Help me says spooling and paper tray not engagged,but the paper is loaded and it says the printer is ready.i have been having problems ever since changing my ink last week,and my printer is only bout 6 months old.this really sucks,i thought i was finally buying a good printer without all the problems as i had with my hp,guess kodak isn't any better!
    Problem Solver:
  • 7 Answers
Most probably the printer that you are using is not set as default, try checking that out from your control panel then try again.
Posted on Nov 18, 2008
My hp2050 pinter won't print itjust shooting blank pages. i dont understand why!
Have you checked that the printer is selected and ticked as being the default printer - also check that all the correct trays are opened and ready for use - some machines give a choice of top loading paper or front loading - paper needs to be in the selected tray in this case
Nov 04, 2012 | HP Deskjet 2050 All-in-One Printer
HP 9050 MFP keeps asking for tray 1. Configuration is set to use tray 4 first, but everytime a print job is sent to the printer, it requests load paper in tray 1. How do I get this problem fixed?
You need to check the paper types you have assigned and the paper types that users are requesting. Print out a configuration page and make sure that Tray 4 shows as plain paper. If it does not then check all the stops. The 2000 sheet tray 4 units are noted for having the stops not engage and this causes the printer to think that tray 4 is custom media. You can also go into diagnostics and print a paper path test for each tray to ensure that all the trays are working.
Apr 21, 2011 | HP LaserJet M9050 MFP Printer
Printer has paper into slots, warning on the status out of paper, how to correct problem?
Your printer is requesting a paper size not loaded in the tray.
Delete the spool or charge the requested paper size or weitght in the tray.
Dec 12, 2010 | HP Officejet H470 InkJet Printer
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
Dec 11, 2010 | Dell 3100cn Laser Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
Microsoft Word displays the following message on the screen: ?Printer out of paper.?
  • The paper trays are empty or overloaded.The paper is curledThe print side, or shiny side, of the paper is not loaded in the input tray face down.The paper might not be engaged with the feed rollers.The paper-width guide is pressed against the paper stack too tightly.The paper tray is not completely inserted into the product.The paper settings in the print driver do not match the paper loaded in the paper tray.The rubber paper-feed rollers are coated with dust.
  • Check the media and print settings
  • Clean the rollers
  • try this. have a nice day.
    Apr 30, 2009 | HP LaserJet 1320 Printer
    My lexmark t520 says "load mp feeder letter"
    Easy one. Open your tray back up and make sure that the paper settings are reflecting the type of paper that is in the tray. The times that I have seen the issue that you just described, the paper setting were off... thus causing this issue.
    If that does not work. Powercycle printer. When it comes ready go to the Paper Menu, then to Default Paper source. Make sure that setting reflects the tray that you would like the printer to print from.
    Hope that helps.
    Mar 19, 2009 | Lexmark T630 Laser Printer
    HP OfficeJet 5510
    What you need to do is manually clear the print queue (Spool).
    To do that create a new text document with notepad and type in the following 4 lines:
    net stop spooler
    del %systemroot%\system32\spool\printers\*.shd
    del %systemroot%\system32\spool\printers\*.spl
    net start spooler
    now save the document and rename it to QueueCleaner.cmd (or whatever you want to call it, just keep the .cmd at the end).
    Now just double click the .cmd file whenever a print job will be stuck and will not delete.
    BTW, you can just type the same 4 commands under Start -> Run if you prefer.
    Aug 08, 2008 | HP Officejet 5510 All-In-One Thermal...
    Kodak EASYSHARE 5100 All-In-One Printer Logo
    54 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
