Question about Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor
The power led is green, but the monitor got no image.
Tried open, but could not do it.
    Genius:
  • 1,605 Answers
Try another monitor, that way you know what is the porblem, the pc or the monitor.the monitor is not repairable.
Posted on Oct 16, 2008
FIX THE COLOR, IT HAS A GREEN TINT THAT DOESN'T GO AWAY WHEN TRYING TO ADJUST COLORS FOR DISPLAY DON'T KNOW WHAT CAUSED IT
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 19, 2015 | Sony BRAVIA KDL-40EX523 40" LED TV...
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
It sometimes takes too long to turn on, and lately it wont turn on t al. the led flashes green for 10 minutes untill it shows image and it started not turning on or showing any image
your power supply may need repair. open the back of it. look for capacitors that are leakingo or crowned. or you can take it to have a shop reepair it.
Dec 25, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
No picture, the power LED alternating between
please your pc in cpu is open and smps power suply in mother board in socket is check and in board in out of rem and cleaning and restore
in press in this plase and monitor cable to cpu add socket is press
and monitor power cable is con't luse and so the restart pc.
other main problem then you go service centre and service currently ok.
Oct 21, 2009 | Computers & Internet
Power light flashes continually but monitor will not work. I leave computer on at all times but turn monitor off. I did that last night but today it was flashing and won't come on or off. I tried turning...
Yes. Flashing LED with no image on the screen is the first sign of the power supply gets overloaded. That may be caused by blown/shorted electrolytic capacitors. Open the monitor, take metal lid off and observe for those caps which are rounded on top. Replace them with proper ones.
Sep 11, 2009 | Acer AL1916W 19" LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Green Power LED is lit- But no image on the screen
Hi, I have just repaired one of these with the same problem. Turned out to be a 680uf 25v capacitor that had failed. Capacitor was visibly domed. Easy repair with new capacitor. Hope this helps.
Aug 10, 2008 | LG Flatron L1715S 17" LCD Monitor
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor Logo
281 people viewed this question
Alun Cox
