Question about Maytag MGR5875QD CleanDesign Gas Kitchen Range
Mgr5875qdw my broiler and oven wont work i set bake and it beeps and the bake light flashes but oven wont lite s
  • 750 Answers
Hello sfgelectric,
Welcome,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Huuum
Remember to leave a rating.
Posted on Oct 16, 2008
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
OVEN WONT LITE. THE GLOW COUPLER GLOWS AND THE BROILER LITES
sounds like this is gas unit . if so replace the bake ( bottom ignitor ) as it is weak . and this should correct problem .. mm hope this helped ..
Jul 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Nov 27, 2008 | Tappan TGF320 Gas Kitchen Range
Kenmore 24" built-in oven wont heat
HI THANKS FOR THE QUESTION oN SOME MODELS THERES A FEATURE THAT IF YOU USED THE TIMER OR THE TIMER SETTINGS MAY HAVE BEEN ACCIDENTLY BEEN CHANGED CHECK TO SEE IF YOU HAVE THE KEEP WARM SETTING ON THE TIMER OR A BURNT OUT BAKE ELEMENT THANKS THEAPPLIANCE DOC
Sep 12, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Open Questions:
Maytag MGR5875QD CleanDesign Gas Kitchen Range Logo
741 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
