JFP1 connection I've recently bought PC components in Germany, this is actually the first PC I'm building myself. Everything went good at first, but when I got to the JFP1 connection, the one for the ON and RESET buttons and the LED lights on the front of the chassis (Coolermaster CM690), I encountered a problem... On the mainboard (K9A2 CF-F) I had 9 pins with POWER, RESET, POWER LED and HDD LED written next to two pins each, of which 1 had a + and 1 had a -. That's all as it should be. On the cable coming from the front of the Coolermaster, though, I only had 4 series of two cables with the same text written on it as on the mainboard, but no + or - anywhere on the POWER, RESET and HDD LED couples. (With couples I mean the + and - wire together, you probably understood but I'm saying just to be sure). Strangely, the POWER LED exists of two wires not attached to each other and they have + and - written on them... But the ones that don't have + or - (AKA the POWER, RESET and HDD LED couples) do have a triangle!!??? on one of the two wires. I need to know wether this triangle means + or -, so I can correctly connect the cables to the motherboard. Yours desperately, Yannick
  • Yannick Verhoog Oct 17, 2008
    Well, I've done some research as well...
    From what I read on WIkipedia, I understood that the triangle can be a diode, which would make sense for the LED lights, and that the wide end of the triangle is the anode, and the tip opposite to it the kathode. The anode should therefor be connected to the - , and the kathode to the +. For the POWER and RESET buttons, though, I wonder if they contain a diode, for those aren't needed there...
    And if there are no diodes, does it matter which wire I connect to a pin??
    Unfortunately, these answers only raise more questions, because I'm not really sure of what I've found.
    If someone would confirm or deny what I'm saying here I'd be very grateful...
    Thanks already!
    I've connected a battery to the LED, and after a little messing around it worked. The arrow apparently indicates the kathode, the + on the mainboard.
    Consider this topic closed.
    PS: how do I actually close a topic. I've still got a problem in my list which is 3 months old...
  • 519 Answers
Hi Yannick,
For the POWER and RESET connectors, it does not matter which way you connect the pairs. Both ways will work. The HDD LED coupler will only work if connected the right way. You can however try it both ways until the LED works. You cannot damage your board if this is connected the wrong way.
Hope this solves your problem.
Posted on Dec 03, 2008
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
Constant crashes during any game
I had this exact problem with my Geforce graphics card. After ensuring that it wasn't overheating, I opened up the PC and reseated (removed and plugged it back in firmly) the graphics card. This actually fixed the issue. Issue caused by a poor connection probably due to too much dust inside the PC.
Failing that, the graphics card would need to be replaced.
Dec 11, 2011 | Power Color Computers & Internet
Hi there, I've just bought an Acer notebook ASPIRE 5750, windows 7 home office. Everything is ok, but softwares like speech recognition, skype and google talk, don't recognize my microphone...
You may have to disable the onboard microphone to use the connected hardware.
Realtek is very picky, same goes with speakers connected to the back and front at the same time, no sound. Disable the one you are not using.
Sep 05, 2011 | Acer Aspire One PC Notebook
Compressor, Condensor Fan and freezer fan not running
have u checked the timer must components are powered by this timer
Jul 24, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Front Panel Connector: JFP1 hookup
You can go to the link below and see the directions for that. Turn to page 2-17
http://www.premioinc.com/pc/manuals/mb/m266/m266.pdf
Sep 21, 2008 | MSI MS-6390 (-6390-010) Motherboard
Sony PS-T3 turntable one-speaker audio
Hey Limber, I am also experiencing that problem with my Sony PS-T3, did you find a solution?
Sep 15, 2008 | Sony CMT-CP505MD CD Shelf System
Service station of fujitsu laptops
To my knowledge most Fujitsu PCs are tied up with Siemens. You can try here, here, or here.
Alternately below are there posted contact information:
Fujitsu Components Europe B.V.
icon_phone.gif Tel: +49-89-32378-600
icon_fax.gif Fax: +49-89-32378-650
Website: emea.fujitsu.com/components/
icon_mail.gifE-mail:info@fceu.fujitsu.com
Address:
Frankfurter Ring 211, Munich, Germany 80807
Fujitsu Deutschland GmbH
icon_phone.gif Tel: +49-89-32378-0
icon_fax.gif Fax: +49-89-32378-100
Website: www.fdg.fujitsu.com
Address:
Good luck and kind regards.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Logitech "RED" Momo
You're right about Logi not providing spares. If you're out of warranty, you are out of luck. If you have the cash I would recommend the G25. Great wheel and the pedals are way better than previous wheels (momo red included) If you want to sell your broken momo, let me know ;) I'm looking for one to build a wheel set up.
Aug 10, 2007 | Logitech MOMO Force Wheel And Pedals Set
Musicmatch says that the music is transfered, but the HDD says no
Make sure that Musicmatch recognises the player as GoGear.
If it shows up as Removable Drive n: (Where n can be any letter) go into the Musicmatch Options menu (with device connected) click on the drop down menu and select GoGear and click apply.
Jan 21, 2007 | Philips HDD070 MP3 Player
Computers & Internet Logo
2,132 people viewed this question
David Payne
David Payne
