Question about Samsung CLP-500 Laser Printer
Transfer roller how do you clear the display error once you change the transfer roller
  • 1 more comment
  • electroapp Mar 11, 2009
    it keeps repeating the same message replace transfer roller soon
    when i have already replaced the belt
  • dhaff128 Mar 18, 2009
    Samsung Laser printer: clp500 will not print. Paper tray is full and red light error on display on back of printer. Will fixing the problem replace transfer belt and or imaging unit?
  • sharon234 Mar 31, 2009
    I have changed the transfer roller but still get the error message to replace it. how do i clear the error message?
    Problem Solver:
  • 8 Answers
Use the keys on the control panel to select the following menus: setup|maintenance|check others|transfer belt|reset then press [enter]. The LCD should read "reset now" and the printer will return to the ready prompt.
This assumes the error message you have is for the transfer belt near end and not the transfer roller itself (which is NOT part of the transfer belt, it's actually attached to the RH door as you look at the control panel).
Posted on May 04, 2009
On our HP printer, you go to MENU, CONFIGURE DEVICE, RESETS, RESET SUPPLIES. Just select which one you changed and tell it yes. Your printer may not be identical, but should be similar.
Posted on Oct 16, 2008
How to clear notification transfer roller needs to be replaced soon.
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Nov 19, 2015 | Genuine Konica Minolta Konica Minolta...
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
SC230
this is an error for the transfer belt there is a mark or the belt has been damaged if you open up th efront cover and then look at the brown panel there are two screws either end that nee to be loosened then lift this up next there is two screws on the transfer unit that run diagonally acros the inside of the machine and a third screw on the black unit (duplex) unit this needs to be taken out.. once you have done this there is a green lever in the top left hand side of the transfer unit this needs to be turned to the left to release the roller take the black duplex unit out by sliding it to the fron then the treansfer unit can be pulled gently out.. it is on two runners so it wont fall off you can hten look at the condition of the belt. if it seems ok look on the edges of the belt by gently turning the gear at the back this will feed the belt around.. if it seems ok put it all back in and then put the srews back in close it up and turn on the machine.. wait for it to warm up.. press the yellow clear/cancel button at the top above the number pad then enter 107 then hold down the cnacel/stop button, hold this down till the screen changes.. turn off the machine and bcak on again.. if the reset has worked the machine should run up and be able to copy and print.. if not you will have to do the same proceedure of clear/cancel button routine and once the screen changes select copy sp then go to section 5.mode then scroll down to 810 sc reset. execute and turn off the machine.. wait 5 secs turn on and test again.. if the error code keeps coming back the B.I.C.U Board may be defective and need to be replaced. check the transfer unit condition of the rollers under the plastic clear image belt also.. Good luck A.
Sep 17, 2009 | Ricoh Aficio 1232C Color Copier
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
Samsung CLP 500 Error message 'Replace transfer roller'
You need to enter the hidden engineer menu: turn the printer off then turn on again whilst holding down the enter key on the control panel. It should say something like EDC menu on the display and you can scroll through several menus to find the one about resetting counters. Be careful not to play with other options as you can screw the printer up if you don't know what you're doing!
Mar 31, 2009 | Samsung CLP-500 Laser Printer
How to clear E000064 problem in ir3300 model
E064
0000 The presence of a high-voltage error is communicated by the composite
power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power
supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly,
or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller,
developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Feb 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Dell CLJ 5110
Pop the lens cover off of the transfer roller, clean all the toner debris out of there and replace the lens, put clear tabe on it, and you are good as new!
Oct 09, 2008 | Dell 5110cn Laser Printer
Samsung CLP-500 Laser Printer Logo
824 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
