I have no power. although when i plug it in after sitting awhile the green light comes on the back saying there is power and as soon as you hit the power button all fans make half a turn and the green light goes out what could be my problem the computer is 6 yrs old and is a compaq presario desktop
  • 6,487 Answers
The problem here is the POwer SUpply Unit of your computer the opne that is responsible in giving power to your computer since its already 6 years the power supply gone bad already and needs a replacement, so what you need to do here is to buy a new Power Supply and repalce it already so you can use the computer again...
Don't forget to rate the solution FIXYA thank you.......
Posted on Oct 16, 2008
    Master:
  • 538 Answers
Power supply is quite clearly unhappy..good news...they do not cost too much..might be able to get one that is twice the rating as that one for same price around 50
The OH Light keeps coming on although the temperature never exceeded 100 degrees.
check your recirculation pump it sounds like it isnt working or plugged filters
Oct 16, 2014 | Pool & Spa
My computer says it is charging but as soon as i hit the power button it stops charging and does nothing even happens
Have you tried running the computer with just the AC plugged in and not with the battery? If not try that. It could be the battery is going out. I had a similar issue once. If that doesn't work it might be the power supply / powercord or it could be the motherboard.
Jan 17, 2013 | IBM ThinkPad T30 2366 Notebook
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
LC 32D43U power and OPC green light flashing set does not come on
hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Dec 29, 2007 | Televison & Video
Computers & Internet Logo
83 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
