FixYa.com
Tags:
Gateway GeForce2 MX400,  AGP Graphic Card
Upgrading Video Drivers NVIDIA GeForce2 MX 400... (by 4 users)
By Rogers - usenet poster
I am having a real problem updating the drivers to this video card. I have
tried updating the Microsoft Drivers which keep coming up on the Windows
Update Site, and the NVIDIA Drivers. Each time I do after the computer
restarts the monitor is blank. I have an LCD (Gateway FPD1819) monitor. I
then start up in safe mode and go to device manager and the monitor doesn't
even show up. I have found no way to load the monitor drivers. When I try
from the Settings tab the monitor tab is present, but the properties button
is grayed out. I have contacted Gateway, but they only seem to want to help
if I download their drivers, which have not been updated in a almost a year.
Does anyone have any idea how I can get this updated and the monitor to
work? Thanks!
Denny
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by jordan123457, posted on Jul 07, 2008
thnx alot i need it really
Comment by sdas, posted on Feb 16, 2008
Comment by porkchissel, posted on Dec 15, 2007
i had the G-2 mx400 ihave a ati 128mb i get to low res and cant play games like call of duty
Best Solution
posted on May 28, 2006
Helpful (85)
Putty
Putty - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Go into device manager and system devices. Delete PCI Bus
and restart your machine. It should redetect everything.
I had a conflict with my AGP slot and an I/O Port in the
PCI bus. Once I rebooted it detected everything fine and
my Geforce card works great.
Steve
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Thanks for Trying (70)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
Thanks Alex I will try this!
Denny
What might help here is to Start - Run and run msconfig.exe
There in the Boot.ini page check the /BASEVIDEO box
Also be *sure* you have all antivirus, firewall disabled (worth
unchecking 'Startup' on the msconfig front page) and reboot.
That should give you a normal - not limited Safe - mode but with just
basic svga in use. Means you have the monitor on normal settings and
the video drivers out of the way while you update them
After of course return the msconfig settings to normal
Alex Nichol MVP (DTS)
Bournemouth, U.K. Alex.N
Check out:'How to make a good newsgroup post'at
Solution #3
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
Thanks Roland. My problem is when I go to add new hardware there is no
choice for adding a monitor. When I select Show All there is still no
choice for a monitor. Thanks for the help though.
Denny
Solution #4
posted on Jul 08, 2008
Not Rated (0)
easyq
Rank:Master Master
Rating: 91%, 5 votes
I think the problem might be NOT monitor related but Media Center related. If you have windows running in a normal mode press CNTRL-ALT-DEL and check under porcesses if EHTRAY.EXE is running. Ifso, this might be the problem, you should delete it from the startup process.
Just read this link on where the file is in your registry.
Solution #5
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Did you find your answer? I'm having the same trouble,
only with an IBM 9516 monitor. I'm pulling my hair out.
Solution #6
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
I will give this a try if Dave's way doesn't work. Thanks!
Denny
Solution #7
Not Rated (0)
Ross
Rating: 0%, 0 votes
Thanks Dave. I will try starting it up with VGA support. I didn't try
that. I did try Show Hidden items and the monitor wasn't listed. Thanks
again. If you come up with anything else, please pass it on.
Denny
Solution #8
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
My experience is that monitors don't require drivers. The
manufacturer provides .INF files which tells Windows the
parameters/specs of the monitor. After you download and
save it go to Add Hardware, select Monitor and chose the
folder which you placed the .INF file in. Then you should
end up with a Monitor in your Device Manager, and your
Monitor's name should be indicated.
As for installing video cards I uninstall/remove the
existing card in Display adaptor line of Device Manager.
Then after a cold reboot it should find a new video card
and ask you for a driver. You would then insert your
driver file. It looks for the .INF file first. Otherwise
go to safe mode and execute the driver install .EXE file.
Good luck.
FPD1819) monitor. I
drivers. When I try
Solution #9
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
Denny I believe you have corruption with your video drivers so I recommend
you delete all of them and then choose while in the safe mode a generic VGA
driver. Load it and reboot normally. Your PC should boot into windows but
your display will look quite terrible. Once there perform a fresh download
of the drivers and try to load these again. The files you need to search for
and get rid of are these:
ALIAGP.SYS - AGP support file for Aladdin TNT2
NVINSTNT.DLL - NVIDIA installation/uninstallation support file
NVOGLNT.DLL - NVIDIA OpenGL driver
NV4_DISP.DLL - NVIDIA display driver
NV4_DISP.INF - Windows 2000/XP display driver information file for NVIDIA
NV4_MINI.SYS - NVIDIA miniport driver
NVCPL.DLL - NVIDIA display properties extension
NVCPL.HLP - NVIDIA display properties extension help file
NVQTWK.DLL - NVIDIA taskbar applet
NVDESK32.DLL - NVIDIA desktop manager
NVDMCPL.DLL - NVIDIA desktop manager hook library
regards
B
Solution #10
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
Denny,
Try restarting and hitting the F8 key until you get to the startup menu for
Windows. There should be an option for startup using the VGA drivers. Select
this and see if it will let you 'see' the bootup screens and your desktop. If
it helps, once Windows is running, it will give you a message that the monitor
setting aren't correct and ask you if you want Windows to adjust them
accordingly, say yes.
Or
When in safe mode and you go to Device Manager, select View and Show Hidden
items, see if this will list your monitor.
HTH,
Dave
Solution #11
Not Rated (0)
Rachel007
Rating: 0%, 0 votes
I have downloaded these drivers and have the same problem. When the
computer restarts the monitor is blank, and when I start in Safe Mode the
monitor does not show up in device manager to be able to install the drivers
for the LCD monitor I have. This is the same problem with Microsoft Drivers
or NVIDIA drivers. ?????
Denny
Forget about the driver update on WindowsUpdate.
Get it manually.
in particular, you are looking for the Detonator XP Driver (Video Cards)
Version: 30.82
File Size: 10.1 MB
Release Date: August 7, 2002
WHQL Certified
Jason Tsang - Windows XP MVP & Associate Expert
Find out about the MS MVP Program -
Find out about the Windows XP Expert Zone -
Solution #12
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
""""Forget about the driver update on WindowsUpdate.
Get it manually.
Version: 30.82
File Size: 10.1 MB
WHQL Certified""""
Thanks for the Nvidia update Jason!
I just downloaded /installed it. The controls are more refined, and I noticed (even rebooted 3 times to be sure) that I now have 6-7 megs more of available RAM at startup.
Solution #13
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Get it manually.
Version: 30.82
File Size: 10.1 MB
WHQL Certified
Can you Help with these Graphics Cards problems?
Graphics Cards
epson c90
i had my epson c 90 for about 6... Answer This...
Graphics Cards
Screen break up/pink 'noise'...
This seems to get worse each... Answer This...
Graphics Cards
capture device on videocard...
I bought a videocard MSI... Answer This...
Graphics Cards
station9ld back again
lost internet connection, will... Answer This...
Graphics Cards
Video Card
I need some help about my... Answer This...
Repair Service
Find Graphics Card Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
