Motobatt mb16a has more cca than the HYB16-AB,the motobatt has 200cca and hyb16 has 150 cca,motorbatt has a 2 year warranty ,andhyb16a has a1 year
SOURCE: 2005 honda shadow spirit 1100. runs with choke on
Have you tried to adjust the tickover screw on the carbs?
SOURCE: Do I use regular or premium gas for my '96 Honda VT 1100 C Shadow
You always want to use the highest octane gas u can find in a motorcycle engine .... 91 at least
SOURCE: Were are the fuses located at on the 2005 Honda VT
Found fuse box, had blown fuse, replaced, blew again, going to mechanic to trace down electrical problem
SOURCE: HOW DO I CHANGE THE
There are two fuel filters on the motorcycle. The filter in the fuel tank is over the inlet tube, is self cleaning, and should never need maintenance. The other is located behind the right side cover next to the fuel pump. You can see the approximate location here. http://www.bikebandit.com/houseofmotorcycles/2006-honda-vt1100c-shadow-spirit/o/m9632#sch414657
