Question about KitchenAid KCM514 Coffee Maker
I have a Kitchenaid coffee pot model KCM515 and have lost the manual. It is not working & display is err4. What does this mean? jgit
  • 145 Answers
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
A .pdf user manual and exploded parts views for this machine are available online at Kitchenaid.com. Click "Customer Care" in the upper-right hand corner of the main page and then click "Locate Manuals and Guides." You will need to enter your model number exactly as it appears on the bottom of the appliance. You should find it on a white sticker.
If this is not helpful, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
My Survival Guide To The Dreaded Err2 Disaster
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Thank you, have a nice day.
Aug 30, 2009 | KitchenAid KCM511 Coffee Maker
Err4 message
On a Kitchenaid coffee maker, ERR 4 indicates a stuck button. Please double check to make sure none of your buttons are sticking in place and "freezing" the coffee maker. If you can not find any obvious problems, I would recommend calling Kitchenaid Customer Service to see what options may be available to you.
Their toll-free phone number is 1-800-541-6390.
Feb 06, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee maker model #kcm515 displays err2--is there anything I can do to fix this? Thank-You! Scott
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Jan 09, 2009 | KitchenAid KCM514 Coffee Maker
Err4
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Dec 31, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
Coffee pot reads err4
We are going to buy a new coffee pot a different brand. We took the 1st one back and now this one
isn't working with an err4 which no one knows what it is but everybody has it!! You want to charge a fee to fix it why??. We paid $60 for that coffee pot and expected it to work longer than 2 years.Your add reads let our experts solve your problem for free. So I click on Chat live now and up comes a page to charge for it so forget it, we will go to a different brand.
Dec 30, 2008 | KitchenAid Coffee Makers & Espresso...
Getting err4 on my cofee pot help
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are compressed into the machine.
Dec 30, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee maker model #KCM534OBO
Err2 is a failed heating element. There is no fix or replacement parts sold. I was lucky I had a receipt, even out of the year warranty they(KitchenAid) are still replacing it.
Nov 07, 2008 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
I have an err4 on my kitchenaid coffee pot. I have unplugged it several times and pushed each button each time but it keeps popping up with the error. It turns on every time I plug it back in before the...
Had the same problem after cleaning. ERR4 is the result of moisture in the electronics. FIRST UNPLUG COFFEE MAKER. Get a long philips screwdriver and remove the 4 screws at the bottom of the coffee maker. Pull the bottom off and carefully unclip the front panel. The circuit card is simply clipped in so it removes nicely by unclipping with your fingers. Now take a hair dryer and dry out the circuit card. Carefully plug the maker back in and verify that the LED nolonger reads ERR4. Reassemble and your back in business!
Sep 07, 2008 | KitchenAid KCM511 Coffee Maker
Re: KitchenAid Coffee Pot
I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
KitchenAid KCM514 Coffee Maker Logo
150 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
