Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
After cleaning- the cooktop did shortcircuit- after resetting the
Circuit breaker the cooktop came on for a split econd and did shortcircuit again - how can this problem be fixed ? thanks franz
    Genius:
  • 1,605 Answers
Since it is a glass top. there must be a crack on the surface. the cleaning liquid short out the elements. and it will stay that way till th liquid dry.
use a hair dryer to heat up the surface and see if you can see the crack. it may be a hairline crack.
once it is dry, it should turn on, unless there something else having a problem.
pleae rate the asnwer if it help in any way
thank you
Posted on Oct 16, 2008
My miele electric cooktop will not stay on after I trip the circuit.
Without more info this is difficult to answer. I will say that all cooktop's have thermal overload switches built into them. They open the circuit until it all cools down and they then close the circuit and reset. You begin using it again and bang it opens again and no power. This means you have a short circuit or a bad overload switch. If you are tripping the circuit breaker, you likely have a short circuit, which is why it is tripping the breaker. I would not keep resetting it, if this is the case. The more you blow or open the breaker the weaker it becomes. They open to prevent an electrical fire, which you do not want.
Nov 03, 2017 | Miele Cooktops
We cleaned to cooktop and now the igniters don't work. the ciruit breaker won't reset and continues to trip
You are short circuiting the cooktop. Make sure no metal is touching the igniters. Check everything again, making sure everything is in place correctly. Also make sure it is fully dry.
Jan 20, 2016 | GE 36 in. JGP628 Gas Cooktop
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Electrolux induction cooktop shuts off and won't turn back on
There is an internal thermal circuit breaker. The breaker has gone bad. On-line of Electrolux find a service manual of your model to locate the breakers location. Contact a local appliance parts store for a replacement also ask for heat sink gel(very small amount). Trip the circuit breaker, remove bad one, clean the space, apply gel and replace it.
May 13, 2010 | Cooktops
The circuit breaker for out kitchenaid glass
Water probably did get into the switch(es). The best bet for a fast fix is to pull the knobs off and use an air can (like for blowing dust out electronics) to blow down into the holes. This will dry out any water in there and should allow you to use it again. To be extra sure, blow out the switches and leave the knobs off over night. In the morning the knobs can be replaced and the cook top should be good to use. Hope this helps!
Dec 11, 2009 | KitchenAid 30 in. Architect KECC507KSS...
Cooktop worked fine until a power outage last night. Can't get the cooktop to work since power restored.
chk for the circuit breakers.they could have triped.reset them again and try.
Aug 11, 2009 | Cooktops
Popping noise and red light
it could be a switch, element or a short somewhere else
Apr 29, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
155 people viewed this question
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
