Question about Hampton Bay 24002 Ceiling Fan
Ceiling fan wires
My bedroom ceiling has 5 dark purple wires, 5 gray wires, one orange wire, and one brown wire. my fan only has black, blue, white and green. the room has 2 switch, 1 switch with dark purple wire and 1 yellow wire; other switch with dark purple, orange and brown wires (brown wire was in the bottom). I don't know how to connect them to the right wires. Please help me to solve this problem, thank you very much!
Kat
  • katie27 Oct 17, 2008
    there is no fixture installed. anyway, I fixed the problem. I used the test-pen to check which one is the hot, and I found out that orange and brown both are hot, so I figure out that fan black connect to orange, and blue connect to brown; and the neutral gray connect to white, and it work.
  • Anonymous Mar 16, 2014
    Where do C22.2NO.190 purple, brown and gray wires go on replacement fan switch Zing Ear ZE-208D?
    Scholar:
  • 61 Answers
Is the old fixture still installed?
Posted on Oct 17, 2008
Need radio wiring diagram for 1988 jeep comanche
  • Constant 12V+ Pink
  • Switched 12V+ Purple/Orange
  • Ground - Black
  • Illumination - Orange/Black
  • Dimmer - Dark Blue/White
  • Antenna Trigger - Gray
  • Front Speakers - 5 1/4" Doors
  • Left Front (+) - Green
  • Left Front (-) - Black/Yellow
  • Right Front (+) - White
  • Right Front (-) - Black
  • Rear Speakers - 5 1/4" Tail Gate
  • Left Rear (+) - Gray/White
  • Left Rear (-) - Brown/White
  • Right Rear (+) - White/Black
  • Right Rear (-) - Brown
Oct 27, 2011 | 1988 Jeep Comanche
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
What do the wiring colours mean?
This is the typical configuration for the wires coming from a car stereo.
Right Rear Spkr (-) = Purple w/ Black Stripe Left Rear Spkr (-) = Green w/ Black Stripe Right Front Spkr (+) = Purple Gray Left Front Spkr (+) = Dark Green White Right Rear Spkr (+) = Blue w/ Orange Stripe Purple Left Rear Spkr (+) = Brown w/ Blue Stripe Green Power Antenna/Amp = Blue +12 Volt Battery Wire = Yellow +12 Volt Ignition Wire = Red Right Front Spkr (-) = Gray w/ Black Stripe Left Front Spkr (-) = White w/ Black Stripe
Jul 07, 2009 | Car Audio & Video
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Clarion M235-RET CD Player
I need the wiring diagram for the radio on a 1994 nissian quest gxe
Constant 12V+ Brown/White
Switched 12V+ Orange
Ground Black/Light Green
Illumination Pink/Black
Dimmer Pink
Front Speakers 5" x 7" Doors
Left Front (+) Gray/Blue
Left Front (-) Yellow/Blue
Right Front (+) Blue
Right Front (-) Yellow
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Blue/White
Left Rear (-) Blue/White
Right Rear (+) Blue/Black
Right Rear (-) Red/Blue
Apr 13, 2009 | 1994 Nissan Quest
Hampton Bay 24002 Ceiling Fan Logo
477 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
