Question about Antec SP450 450W SmartPower ATX 2.0 20/24 Pin ATX Connector Power Supply (SP450) (PS450ANSP450) Power Supply
No Power Hi all, I have the SP 450 running on a machine I built about two years ago. I have experienced no problems since then...until yesterday. I hit the power switch and nothing happens. I checked all connections to ensure they were intact and found all to be intact. Are there any known issues with this PSU? Should I need another power supply, what are some good power supplies out there currently? I have a working knowledge of computers and can do stuff as long as it is explained well. Thanks for the help in advance! Press the start button nothing happens, no fans start. The ASUS Motherboard's LED SB_Power is lit so part of the Powersupply is working. Bill
    Genius:
  • 1,605 Answers
Take off the hard drive and the meories. fire it up. if it comes up , replace the item you taken off one at a time. you will find the porblem.
Posted on Oct 16, 2008
2 Suggested Answers
SOURCE: No Power
Thanks for the suggestions guys. I"ll try'em out and let ya know what happens.
Posted on Feb 29, 2008
Lawn mowers
Maybe it need a spark plug
May 08, 2013 | Garden
When I turned on my PC, the blue light was on, but, the video screen was blank (Dark). I read the solutions in web site, they suggested to replace main board or RAM. Here, I don't know if it is worthy...
Hi, Turn off the computer and open the side cover by removing two screws. If you have a video card remove it and clean the connectors with alcohol and also the memory card connectors. Re install it and install it back the side cover and turn the power that should work for you. Get back to us if this information helps you solve the problem. Good day...
Jul 13, 2011 | Acer Aspire m5640 PC Desktop
Error sc 551
try to SP reset then lets see what code appears
SP RESET
press Clear Mode 2x
107
press Clear Mode for 5 sec or until Copy Sp appears
Press Copy Sp
Exit
Turn off machine then on after 5 to 10 sec.
Aug 23, 2010 | Ricoh Aficio 450 Copier
Sc 545
SC545 means the fiser is not detecting the temperature correctly.
Try this , the Clear all button ( yellow) then enter 107 then press and hold the stop button until the screen comes on with the SP screen. Press copy SP and then power the machine off.
If the fault comes back you will have to either clean , or more likely replace the fuser thermistors. Also look for a papper wrap in the fuser module.
Aug 11, 2010 | Ricoh Aficio 450 Copier
No water goes into dishwasher. Dishwasher has only been used 2times. Came new with house 3.6 years ago. Pulled front panel off...everything appears to be connected motor fan runs.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Jan 04, 2010 | GE Nautilus 24" Built-in Dishwasher
Functional problem SC548-00
Try to reset the code, CLR modes key, then 1 then 0 then 7 and hold the red CLR/STOP key until your screen changes. press option 1 copy SP, then flip the red power switch on the left side of your machine. if you cant locate the switch unplug, but it is much better to use the switch
Dec 14, 2009 | Ricoh Aficio 450 Copier
Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
May 29, 2009 | Ricoh Aficio 450 Copier
Panasonic Super Drive video recorder
there are three creases in the head , have you made sure those are cleard?
Oct 21, 2008 | Zenith VCS442 VHS VCR
Computer
Can think of only three possibilities:
1. CPU fan motor, bearings needs lubrication or replacement;
2. Power Supply fan motor, same as above or any of the other fans;
3. Hard disk spindle motor (though unlikely).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Computers & Internet
No Power
Hi, remove your power supply from the case, onen it and remove all dust from it. Inside you should see a glass fuse, if tis is blown replace it and all should be ok.
If the fuse is intact test it with a multi meter, [this can also be done across a light and wires with a battery] If you find the fuse intact and still have no power then replace the PSU with any simalar watt unit. The only brand I would advise against is Ritmo as these are not a high quality PSU. There are quite a range of brand names which can be purchased on Ebay.
Goodluck mistyman
Feb 27, 2008 | Antec SP450 450W SmartPower ATX 2.0 20/24...
Antec SP450 450W SmartPower ATX 2.0 20/24 Pin ATX Connector Power Supply (SP450) (PS450ANSP450) Power Supply Logo
331 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
