Question about Garden
Flymo micro lite - cutting height of blade
Is there a height adjustment facility on the flymo mcro lite?
How do I remove the blade plate underneath the mower?
  • 1 more comment
  • Anonymous Mar 27, 2014
    i want to remove the blades and replace with 2 plastic blades
    i want to replace the blades with plastic ones
  • Anonymous Mar 29, 2014
    It is a flymo lite xlt. 250+
You twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Posted on Jun 28, 2009
Flymo instruction manuals
Jul 14, 2014 | Garden
How do i lower the cut on my flymo hover 2800
remove the blade from bottom you will see many rings around the shaft of engine just place bellow or above your blade to adjust height .
Mar 11, 2014 | Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
How to fit belt on flymo tc380
Too replace the belt you need to remove the motor and base plate assembly, remove the box, remove the front cover over the motor, pull the two wires off the motor terminals, turn the mower upside down,remove the blade bolt and blade, remove the impellor, remove the four cross head screws underneath, there are two more screws toward the front of the machine, once all out the motor and base plate will come out as an assenbly, slacken the four motor screws and push the motor forward, remove the old belt and fit the new one, wedge a screw driver between the motor housing and base plate force the motot forward to tention the belt at the same time re tighten the motor screws, re assemble in the reverse order.
Jun 16, 2012 | Garden
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
How to change the saw blade
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
Fig. 43
arbor shaft
Fig. 44
Fig. 4535
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Can the blade height be adjusted on the flymo 300 compact?
the blade shape can not be changed they are heat treated and if bent they will break, the only way to change the blade height is by changing the blade adapter.
Apr 05, 2009 | Garden
I have a juki mo-3614 serger and I can't seem to get the blades lined up right for cutting. It just seems to want to roll the fabric instead of cut it. How do I line up the blades the right way.
first, pull out the bvlades and make surte they are sharp. It could simply be that they are dull. Next, line tyhe bottom blade up level to the surface of the needle plate. The top blade should be adjusted to where it slices against the botom blade. You may have to experiment with the height adjustment on the top blade, assuming you have a suitable cutting edge.
Nov 29, 2008 | Juki MO-644D Mechanical Sewing Machine
Garden Logo
797 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
